Dear Kim san,
> Long time no see, I am glad to see your message 🙂
Same here, really.
I understand that your suggestion is to change the priority of
the threads not on EPICS-base but on Linux. How smart you are!
I did not know the chrt command of Linux. I appreciate the
teaching of yours.
Best regards,
J.Odagiri at KEK
----- Original Message -----
> Dear Odagiri san,
> > Can I change the priority of "CAS-TCP" thread and "scan-10"
> > thread so that the former is given a higher priority than
> > that of the latter without modifying any source files in
> > base?
> It is possible to modify thread priority after the launching process,
even possible to modify the scheduling policy (ex, SCHED_OTERH to SCHED_
FIFO, to the real-time priority).
> Please, check up the followings:
> I am using linuxRT - preempted rt patch for this example.
> uname -a
> Linux cpu-b084-pm01 4.14.139-rt66 #1 SMP PREEMPT RT Mon Sep 30 14:33:
17 PDT 2019 x86_64 GNU/Linux
> We can check up process id, parent id, thread id, rt-priority, start
time, running time, and thread name with the following command.
> ps -Leo pid,ppid,tid,rtprio,stime,time,comm
> 21994 21993 22010 - Mar23 00:00:00 tpg
> 21994 21993 22011 - Mar23 00:00:00 tpg
> 21994 21993 22209 59 Mar23 00:00:00 timerQueue
> 21994 21993 22210 59 Mar23 00:00:00 timerQueue
> 21994 21993 22212 - Mar23 00:00:00 tpg
> 21994 21993 22215 - Mar23 00:00:00 tpg
> 21994 21993 22216 10 Mar23 00:00:00 taskwd
> 21994 21993 22217 69 Mar23 00:00:00 timerQueue
> 21994 21993 22218 58 Mar23 00:01:39 cbLow
> 21994 21993 22219 63 Mar23 00:00:00 cbMedium
> 21994 21993 22220 70 Mar23 00:00:00 cbHigh
> 21994 21993 22221 50 Mar23 00:00:00 dbCaLink
> 21994 21993 22222 98 Mar23 00:12:35 tpgIrqPollingTa
> 21994 21993 22223 89 Mar23 00:04:02 tpgSoftPollingT
> 21994 21993 22224 50 Mar23 00:02:59 tpgBsaPollingTa
> 21994 21993 22225 10 Mar23 00:01:13 tpgRateMeasureP
> 21994 21993 22226 10 Mar23 00:02:07 tpgDiagnosticsT
> 21994 21993 22227 50 Mar23 00:02:40 bsaDrvPoll
> 21994 21993 22228 57 Mar23 00:00:13 timerQueue
> 21994 21993 22229 66 Mar23 00:00:00 scanOnce
> 21994 21993 22230 59 Mar23 00:00:00 scan-10
> 21994 21993 22231 60 Mar23 00:00:00 scan-5
> 21994 21993 22232 61 Mar23 00:00:01 scan-2
> 21994 21993 22233 62 Mar23 00:00:07 scan-1
> 21994 21993 22234 63 Mar23 00:00:14 scan-0.5
> 21994 21993 22235 64 Mar23 00:00:09 scan-0.2
> 21994 21993 22236 65 Mar23 00:00:18 scan-0.1
> 21994 21993 22237 56 Mar23 00:00:00 asCaTask
> 21994 21993 22238 16 Mar23 00:00:00 CAS-TCP
> 21994 21993 22239 12 Mar23 00:00:54 CAS-UDP
> 21994 21993 22240 14 Mar23 00:00:00 CAS-beacon
> 21994 21993 22241 51 Mar23 00:00:00 CAC-event
> 21994 21993 22242 10 Mar23 00:00:00 logRestart
> 21994 21993 22243 10 Mar23 00:00:00 caPutLog
> 21994 21993 22244 20 Mar23 00:00:24 save_restore
> 21994 21993 22245 10 Mar23 00:00:00 ipToAsciiProxy
> 21994 21993 22246 22 Mar23 00:01:42 timerQueue
> 21994 21993 22247 24 Mar23 00:00:27 CAC-UDP
> 21994 21993 22250 22 Mar23 00:00:04 CAC-event
> 21994 21993 22778 18 08:36 00:00:00 CAS-event
> 21994 21993 22779 20 08:36 00:00:00 CAS-client
> 22756 6877 22756 - 08:28 00:00:00 dropbear
> The 3rd column is thread id, and the 4th column is a priority. The
symbol "-" means no rt-priority for the thread, SCHED_OTHER.
> The thread "scan-10" has thread id 22230 and rt-priority 59.
> The thread "CAS-TCP" has thread id 22238 and rt-priority 16.
> If we want to escalate the rt-priority for those threads, we can do
the followings:
> # Escalate rt-priority of scan-10 to 60
> chrt -f -p 60 22230
> pid 22230's current scheduling policy: SCHED_FIFO
> pid 22230's current scheduling priority: 59
> pid 22230's new scheduling policy: SCHED_FIFO
> pid 22230's new scheduling priority: 6
> # Escalate rt-priority of CAS-TCP to 20
> chrt -f -p 20 22238
> pid 22238's current scheduling policy: SCHED_FIFO
> pid 22238's current scheduling priority: 16
> pid 22238's new scheduling policy: SCHED_FIFO
> pid 22238's new scheduling priority: 20
> Then, you can see the priorities of those two threads were escalated.
> 21994 21993 22230 60 Mar23 00:00:00 scan-10 <==========
59 to 60
> 21994 21993 22238 20 Mar23 00:00:00 CAS-TCP <========= 16 to
20
> I think the help message of the "chrt" will be helpful.
> chrt --help
> BusyBox v1.31.0 (2019-09-30 13:30:59 PDT) multi-call binary.
> Usage: chrt -m | -p [PRIO] PID | [-rfobi] PRIO PROG [ARGS]
> Change scheduling priority and class for a process
> -m Show min/max priorities
> -p Operate on PID
> -r Set SCHED_RR class
> -f Set SCHED_FIFO class
> -o Set SCHED_OTHER class
> -b Set SCHED_BATCH class
> -i Set SCHED_IDLE class
> Thank you.
> Best regards,
> Kukhee
> ________________________________
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of jun-ichi.
odagiri--- via Tech-talk <tech-talk at aps.anl.gov>
> Sent: Friday, March 26, 2021 12:09 AM
> To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> Subject: Re: Changing EPICS general Purpose Thread's Priorities
> Dear Han san,
> Thank you for sending me the information.
> I took a look at the site you have let me know.
> But, I may be dense, I could not get the point.
> It seems like that the information on the site is related
> to Multi-Core Linux.
> To be more concrete, I tell you what I have in my mind as
> follows.
> 1. A Single-Core CPU is running Linux.
> 2. Only one IOC program is running on the Linux.
> 3. The IOC program is multi-threaded, as every one knows.
> Here is my question.
> base?
> Does the site you guided me to answer the question?
> Thanks a lot again in advance.
> Best regards,
> J.Odagiri at KEK.
> > Jun-ichi Odagiri san,
> > This may be what you are looking for.
> > https://github.com/epics-modules/MCoreUtils
> > Best,
> > Han
> > On Thu, Mar 25, 2021 at 4:55 PM jun-ichi.odagiri--- via Tech-talk
> > <tech-talk at aps.anl.gov> wrote:
> > > Hi, all
> > > Do we have a way to change the priorities of the EPICS
> > > general purpose threads dynamically on the iocsh?
> > > Thanks a lot in advance.
> > > Jun-ichi Odagiri(KEK)
- Re: Changing EPICS general Purpose Thread's Priorities Kim, Kukhee via Tech-talk
Re: Changing EPICS general Purpose Thread's Priorities William Layne via Tech-talk
Re: Changing EPICS general Purpose Thread's Priorities jun-ichi.odagiri--- via Tech-talk
<2021>
Support for CAEN DT5730 / DT5730S? Mark Rivers via Tech-talk
<2021>
