1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Rate of change calculation
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: Tech-talk <[email protected]>
Date: Mon, 29 Mar 2021 13:35:08 +0200
Hello,
I am trying to calculate the rate of change of a record using a calc record as follows:
record(ai, "$(KEIT):Charge")
    field(DESC, "Measure Charge")
    field(DTYP, "steam")
    field("@devKeithley6514.proto measureCharge() $(PORT)")
    field(SCAN, "Passive")
record(calc, "$(KEIT):CalcCurrent")
    field(SCAN, "1 second")
    field(INPA, "$(KEIT):Charge PP")
    field(INPB, "$(KEIT):Charge NPP")
    field(CALC, "B-A")
The calc record always returns 0. If I change the calc to B+A, to check what is going on, I always get double the charge. It seems like the PP and NPP are both returning the same value even though the actual charge is changing. Any ideas on why this would be happening or suggestions would be greatly appreciated.
Thank you in advance,
Donny
Donny Domagoj Cosic
 Institut Ruđer Bošković, Bijenička cesta 54, 10000 Zagreb, Croatia
Re: Rate of change calculation Smith, Martin via Tech-talk
Re: Rate of change calculation Mark Rivers via Tech-talk
Prev: CS-Studio Databrowser historical data display Vishnu Patel via Tech-talk
Next: Re: Rate of change calculation Smith, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: CS-Studio Databrowser historical data display Kasemir, Kay via Tech-talk
