1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Subject: RE: Area Detector and Flea2 camera problem
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: 'Miroslaw Dach' <mdach at lbl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 29 Mar 2021 23:00:44 +0000
Hi Mirek,
Ø  Does it mean that the Flea2 would work with area-detector under Windows?
In principle yes.  It should work on Linux too, I just don’t know if it has been tested.
I actually have a Flea2 camera (FL2-03S2M).  I just plugged it into my Windows machine.  The FLIR FlyCap2 viewer software is not finding the camera, but it should.  I have sent a support request to FLIR to have them help me with that problem.  If they can figure it out I will see if ADPointGrey works with the camera on Windows.  I don’t have a Linux machine with a Firewire card, so I can’t test that.
Sent: Monday, March 29, 2021 4:57 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk at aps.anl.gov
Subject: Re: Area Detector and Flea2 camera problem
Hi Mark and Han,
Thank you very much for your expertise and suggestions.
>This means that the vendor SDK is unable to find any Point Grey/FLIR cameras.
I will just give a last try. I will read the serial number and set it explicitly in EPICS db.
>The Flea2 is a Firewire camera.  In principle that is supported by the FlyCap2 SDK that ADPointGrey uses.  However, I am not sure if anyone has actually used a Point Grey Firewire camera with ADPointGrey on Linux, and almost certainly not on a Ubuntu 20.
>Is replacing the camera an option?  New GigE or USB-3.0 cameras with much better performance than the Flea2 are less than $500.
Well, we just have this camera so we wanted to make use of it even if it is not so new.
Best Regards
Mirek
On Thu, Mar 25, 2021 at 7:20 PM Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Mirek,
> Number of cameras detected: 0
> 2021/03/25 17:56:30.674 pointGrey:connectCamera: no cameras found
Firewire cameras are not supported by the new FLIR Spinnaker SDK, so upgrading to that is not an option.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Miroslaw Dach via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, March 25, 2021 8:09 PM
To: tech-talk at aps.anl.gov
Subject: Area Detector and Flea2 camera problem
Hello,
I am using the latest Area Detector R3-10 on Ubuntu 20.04 focal (x86-64).
Unfortunately the Flea2 camera which is connected to the computer is not detected:
Startup script:
epicsEnvSet("IOC","iocPointGrey")
epicsEnvSet("TOP","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC")
epicsEnvSet("ADPOINTGREY","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/../..")
epicsEnvSet("SUPPORT","/home/beamline/EPICS/synApps/support")
epicsEnvSet("ASYN","/home/beamline/EPICS/synApps/support/asyn-R4-41")
epicsEnvSet("AREA_DETECTOR","/home/beamline/EPICS/synApps/support/areaDetector-R3-10")
epicsEnvSet("ADSUPPORT","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADSupport")
epicsEnvSet("ADCORE","/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADCore")
epicsEnvSet("AUTOSAVE","/home/beamline/EPICS/synApps/support/autosave-R5-10-2")
epicsEnvSet("BUSY","/home/beamline/EPICS/synApps/support/busy-R1-7-3")
epicsEnvSet("CALC","/home/beamline/EPICS/synApps/support/calc-R3-7-4")
epicsEnvSet("SNCSEQ","/home/beamline/EPICS/synApps/support/seq-2-2-8")
epicsEnvSet("SSCAN","/home/beamline/EPICS/synApps/support/sscan-R2-11-4")
epicsEnvSet("DEVIOCSTATS","/home/beamline/EPICS/synApps/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/home/beamline/EPICS/base-7.0.5")
errlogInit(20000)
dbLoadDatabase("/home/beamline/EPICS/synApps/support/areaDetector-R3-10/ADPointGrey/iocs/pointGreyIOC/dbd/pointGreyApp.dbd")
# Prefix for all records
epicsEnvSet("PREFIX", "13PG1:")
# Use this line for the first Point Grey camera in the system
epicsEnvSet("CAMERA_ID", "0")
# Use this line for a specific camera by serial number, in this case a Flea2 Firewire camera
epicsEnvSet("CAMERA_ID", "9211601")
pointGreyConfig("PG1", 18402100, 0x1, 0)
2021/03/25 17:56:30.651 pointGrey:connectCamera: no cameras found
2021/03/25 17:56:30.651 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
2021/03/25 17:56:30.651 pointGrey:pointGrey:  camera connection failed (3)
2021/03/25 17:56:30.674 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
2021/03/25 17:56:30.674 pointGrey::report error calling connectCamera()
Supported properties
./start_epics: line 1: 78175 Segmentation fault      (core dumped) ../../bin/linux-x86_64/pointGreyApp st.cmd
kernel reports the following problem:
692673.933782] pointGreyApp[78175]: segfault at 0 ip 00007f56601b1a1f sp 00007ffecc98aa50 error 4 in libpointGrey.so[7f56601a4000+11000]
[692673.933794] Code: 84 9f 04 00 00 48 8b 85 30 e8 ff ff 49 8b b7 60 05 00 00 48 8b bd 38 e8 ff ff 49 8b 94 07 c8 05 00 00 4d 8b b4 07 58 06 00 00 <48> 8b 06 48 89 95 20 e8 ff ff ff 50 78 48 8b b5 38 e8 ff ff 4c 89
Does anybody have an idea what might be wrong?
Best Regards
Mirek
RE: Area Detector and Flea2 camera problem Heesterman, Peter J via Tech-talk
Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Re: Area Detector and Flea2 camera problem Mark Rivers via Tech-talk
Re: Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Prev: Re: Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Next: RE: Question about ACROMAG IP-408 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Next: RE: Area Detector and Flea2 camera problem Heesterman, Peter J via Tech-talk
ANJ, 30 Mar 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
