1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Questions about arrays
From: William Layne via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: "Wang, Andrew" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 30 Mar 2021 12:22:42 -0400
Unsure if this is still relevant, but I remember there being talk about trying to get channel filters working on put operations. Do you know if that's still being discussed, or even possible? If it is, it could possibly solve this question in the future.
William
On Tue, Mar 30, 2021, 11:57 AM Johnson, Andrew N. via Tech-talk <[email protected]> wrote:
Hi Andy,
On Mar 29, 2021, at 10:55 PM, Wang, Andrew wrote:
> I have two questions pertaining to the array records in EPICS 3.15.
>       • Suppose I have an analog input array or waveform record of size 5 that contains the values 1, 2, 3, 4, 5. Suppose I want to replace with the fourth element. Based upon what I've read, it doesn't seem like subArray is a viable choice. I've also tried to use caput but to no avail. Any recommendations other than using aSub?
Arrays have historically been second-class citizens in the EPICS database, and we don’t have many generic ways of processing them. As you’ve discovered the subArray cannot do what you want by itself.
The latest release of EPICS 7 has added a few improvements to the internals so with that release it’s possible to handle zero-element arrays, and to extract parts of an array using a DB link. We haven’t added any more record types though, so at the moment the aSub and acalcout are the best ways to handle that in the database, or you could use an SNL program but you might want to move more of the array processing into SNL if you do that since moving data between the IOC and the SNL program isn’t particularly efficient.
>       • Suppose I have eight individual analog input records and I want to "concatenate their values" and store the result into an analog input array record. I'm thinking about using either aCalcout or an aub routine. Are those valid options and if not, what are alternative options I should explore?
I would suggest an aSub for that, it has lots of inputs with links for fetching the individual data points, and should be a bit more efficient than an acalcout although it does mean you would have to write some C code.
Your questions do show that we could do with adding some new record types to Base for handling these kinds of operations.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Questions about arrays Johnson, Andrew N. via Tech-talk
Re: Questions about arrays Ben Franksen via Tech-talk
Questions about arrays Wang, Andrew via Tech-talk
Prev: Re: Questions about arrays Johnson, Andrew N. via Tech-talk
Next: Re: Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Questions about arrays Johnson, Andrew N. via Tech-talk
