1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Questions about arrays
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: William Layne <[email protected]>
Cc: "Wang, Andrew" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 30 Mar 2021 17:25:36 +0000
Hi William,
On Mar 30, 2021, at 11:22 AM, William Layne <[email protected]> wrote:
> Unsure if this is still relevant, but I remember there being talk about trying to get channel filters working on put operations. Do you know if that's still being discussed, or even possible? If it is, it could possibly solve this question in the future.
There is no support inside the EPICS 7.0.5 IOC at the moment for running channel filters on puts, and I’m not sure how easy it will be to let filters modify an existing array field instead of just overwriting it with a new value (which is what the existing put API implements).
Another complexity that I see is agreeing on the semantics of what it should mean to run commands like these:
$ caput ‘array1.[4]' 100
$ caput -a ‘array2.[2:3]' 5 1 2 3 4 5
If array1 holds doubles and starts out empty, would the first command set elements 0 through 3 to NaN values, or to zeros? Presumably the second command would leave the first 2 elements of array2 alone, replace elements 2 and 3 with the values 1 and 2, then insert the values 3 4 5 after element 3. Unfortunately implementing these might be tricky without breaking the support for circular buffers that the array field API currently provides.
Thus I wouldn’t hold your breath waiting, although I’m not trying to discourage Ben or Dirk from looking at these kinds of questions.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Questions about arrays William Layne via Tech-talk
Re: Questions about arrays Ben Franksen via Tech-talk
Questions about arrays Wang, Andrew via Tech-talk
Re: Questions about arrays Johnson, Andrew N. via Tech-talk
Prev: Re: Area Detector and Flea2 camera problem Miroslaw Dach via Tech-talk
Next: Asyn Stopping Transfer Short Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Questions about arrays William Layne via Tech-talk
Next: Re: Questions about arrays William Layne via Tech-talk
