1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Interrupts in Linux
From: "Siddons, David via Tech-talk" <[email protected]>
Date: Mon, 5 Apr 2021 12:49:30 +0000
I have an embedded Linux system based on the ZynQ processor. I have the FPGA configured to generate a hardware interrupt whenever data is ready to be read. The frequency of the interrupts depends on the integration time of the measurement, and should be settable from seconds to around one millisecond. This is all within an EPICS IOC running under ARM Linux, in a Debian 10 system. What I observe is that the maximum frequency I can use is 100Hz, which is the Linux system clock tick frequency. Presumably there is a lock somewhere inhibiting interrupts except at tick time. I tried rebuilding the kernel with the PREEMPT-RT patch enabled, but it seems not to make a difference. I am definitely not a kernel expert; does anyone know what I'm missing?
Pete.
Re: Interrupts in Linux Till Straumann via Tech-talk
Prev: Documentation to program CSS Phoebus scripts using JS and Python Oscar Ibañez via Tech-talk
Next: Re: Interrupts in Linux Till Straumann via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Documentation to program CSS Phoebus scripts using JS and Python Johnson, Andrew N. via Tech-talk
