1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: External: Re: problems with running EPICS Gateway on virtual machines?
From: Ru Igarashi via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 14 Apr 2021 07:04:26 +0000
Yong,
Thanks for the -no_cache suggestion.  It did stop the problem but is not
a long term solution because I'm relying on caching so that the
gateway can act as a proxy or channel access concentrator (to
reduce traffic).
The -w option doesn't help.  That's very likely because the response
updates for errant transactions are coming in well under 1 s, i.e.
right after the record finishes processing from the caput.  Recall
that I reported a caget right after the caput has the correct value.
That's happening well under 1 second after the caput.  I think
this is some sort of borderline timing issue.
I have to try Hugo's suggestion of running v2.0.6.
ru
Sent: Tuesday, April 13, 2021 20:09
To: Johnson, Andrew N.; Ru Igarashi
Cc: EPICS tech-talk
Hi Ru,
To turn off caching, add the option "-no_cache" in your gateway command.
Since you use "caput -c pvName", I guess "pvName" seems to be an asynchronous record. You can try this to find out how much time the command "caput -c" takes: time(caput -c pvName).
Another try: increase to the default timeout (1 second) to a bigger number (10 seconds), i.e. caput -c -w 10 pvName
HTH,
Yong
On 4/13/21, 5:52 PM, "Tech-talk on behalf of Johnson, Andrew N. via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    What happens when you run a camonitor on the PV(s) at the same time as you do the put, does it show the full sequence that you're expecting?
    ISTR there is a configuration setting for the CA gateway which can turn off cacheing, which may be what you want for one that you’re going caputs through; maybe someone else with more knowledge can comment on that.
    - Andrew
    > On Apr 13, 2021, at 4:33 PM, Ru Igarashi via Tech-talk <[email protected]> wrote:
    > Hello Hugo,
    > Neither camonitor nor caget shows bad timestamps.  Also, I forgot
    > to mention that, when I do a caget right after a caput -c it returns
    > with the correct value, and running a parallel camonitor exacerbates
    > the problem.  I plan on running more detailed tests with caget and
    > camonitor, and with debugging turned on.  But I would like to know
    > if this is a familiar problem or that running CA Gateways on VMWare
    > is a bad idea to begin with (I had big latency problems many years
    > ago, so I went to a hardware solution at that time).
    > ru
    > From: Hugo Slepicka <[email protected]>
    > Sent: Tuesday, April 13, 2021 12:56
    > To: Ru Igarashi
    > Cc: [email protected]
    > Subject: External: Re: problems with running EPICS Gateway on virtual machines?
    > Hi Ru,
    > Could you check if doing a caget -a shows the timestamp as undefined?
    > Another thing is: could you try to downgrade R2.0.6 and see if it works?
    > Cheers,
    > Hugo
    > On Tue, Apr 13, 2021 at 10:44 AM Ru Igarashi via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
    > Hello,
    > I have at least one problem with running EPICS CA Gateway 2.1.2
    > on Scientific Linux/Redhat Enterprise Linux 7 with EPICS 3.14.12.4.
    > For IOC's running EPICS 7 on CentOS 8 and clients on older OS and
    > EPICS 3.14.12, the readback value for asynchronous 'caput' commands
    > (caput -c) are often the old value, not new value.  I have an older
    > gateway running on old hardware, OS and EPICS which also does this
    > but 100 times LESS frequently for the same type of IOC and client.
    > The other difference between the two set-ups is that the new
    > gateway is running on a virtual server (VMWare) and the old gateway
    > is running on hardware.
    > Further, when I see these errors, packet captures show the only
    > differences in behaviour are that:
    > - on the client side of the gateway, in the bad transaction, the
    > "update" packet that follows the "write" arrives after the write
    > is acknowledged whereas normal transactions have the
    > acknowledgement packet arrive after the "update" packet.
    > - on the server side of the gateway, in the bad transaction, the
    > "update" packet carries a data payload of zeros in all bytes,
    > whereas normal transactions have non-zero data payloads.
    > It looks as if updates from the IOC are arriving late and
    > the gateway is returning unusable data.
    > I haven't ruled out server performance yet, but before I sink
    > any more time into this, I'd like to ask, has anyone
    > experienced problems running Gateways on virtual servers?
    > Or could this be due to running the gateway on newer, higher
    > performance machines, or due to mismatches in the way channel
    > access is handled by EPICS 7 versus 3.14.12.4?
    > ru
    Complexity comes for free, simplicity you have to work for.
Re: External: Re: problems with running EPICS Gateway on virtual machines? Ralph Lange via Tech-talk
Re: External: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Re: problems with running EPICS Gateway on virtual machines? Hugo Slepicka via Tech-talk
Re: External: Re: problems with running EPICS Gateway on virtual machines? Johnson, Andrew N. via Tech-talk
Re: External: Re: problems with running EPICS Gateway on virtual machines? Hu, Yong via Tech-talk
Prev: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Next: Re: External: Re: problems with running EPICS Gateway on virtual machines? Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: External: Re: problems with running EPICS Gateway on virtual machines? Hu, Yong via Tech-talk
