1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: External: Re: problems with running EPICS Gateway on virtual machines?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 14 Apr 2021 10:06:27 +0200
On Wed, 14 Apr 2021 at 09:04, Ru Igarashi via Tech-talk <[email protected]> wrote:
Thanks for the -no_cache suggestion.  It did stop the problem but is not
a long term solution because I'm relying on caching so that the
gateway can act as a proxy or channel access concentrator (to
reduce traffic).
The '-no_cache' option stops the Gateway from answering CA get() requests directly from its internal data cache. Instead, the Gateway will forward all get() requests to the IOC and relay the IOC answer back to the client.
This option does not change the Gateway behavior regarding subscriptions, i.e., it will still "concentrate" many identical subscriptions by its clients into a single subscription to the IOC and do the fanning out of updates.
Original motivation for the '-no_cache' option was the chance of visible inconsistencies introduced by the cache, where - assuming an analog value with a deadband for monitor updates - a client would get a different value directly from the IOC (the actual current value) than from the Gateway (the last monitor update from the IOC that may differ by the deadband width).
Again: For subscriptions, '-no_cache' or not should not make any difference.
Cheers,
~Ralph
problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Re: problems with running EPICS Gateway on virtual machines? Hugo Slepicka via Tech-talk
Re: External: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Re: External: Re: problems with running EPICS Gateway on virtual machines? Johnson, Andrew N. via Tech-talk
Re: External: Re: problems with running EPICS Gateway on virtual machines? Hu, Yong via Tech-talk
Prev: Re: External: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
Next: Re: External: Re: problems with running EPICS Gateway on virtual machines? Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: External: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
