1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: WIN_32
From: Marty Kraimer via Tech-talk <tech-talk at aps.anl.gov>
To: Freddie Akeroyd - STFC UKRI <freddie.akeroyd at stfc.ac.uk>
Cc: tech talk <tech-talk at aps.anl.gov>
Date: Sat, 17 Apr 2021 17:34:03 -0400
On 4/17/21 4:54 PM, Freddie Akeroyd - STFC UKRI wrote:
Hi Marty,
Do you also build your programs linked statically on linux too? If not, it might be worth doing that too - I believe any purely link order issues you may see with travis windows should also occur when linking statically on linux
Freddie
How do I do this on Linux?
I also have a couple of questions about the travis  builds.
1) Why are there two sets of builds,
2) Do  any of the gcc or clang builds statically linked.
Marty
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via
Tech-talk
Sent: 17 April 2021 13:37
To: Marty Kraimer <mrkraimer at comcast.net>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Subject: Re: WIN_32
Hi Marty,
You are making progress, the error is now different:
/home/travis/.source/pvaClient/lib/linux-x86_64/libpvaClient.a(pvaClient.o): In
function `epics::pvaClient::PvaClient::~PvaClient()':
/home/travis/.source/pvaClient/src/O.linux-x86_64/../pvaClient.cpp:156:
undefined reference to `epics::pvAccess::ClientFactory::stop()'
So now a function in pvaClient is not finding the pvAccess functions.  That is
probably a link order problem.
Try this:
EPICS_BASE_PVA_CORE_LIBS =  pvaClient  pvDatabase pvAccess pvAccessCA
pvData Com
Or leave EPICS_BASE_PVA_CORE_LIBS as it was originally and add pvaClient
here:
PROD_HOST += serviceMain
serviceMain_SRCS += serviceMain.cpp
serviceMain_LIBS += controlRecord
serviceMain_LIBS += powerSupplyRecord
serviceMain_LIBS += linkRecord
serviceMain_LIBS += pvaClient
serviceMain_LIBS +=  $(EPICS_BASE_PVA_CORE_LIBS)
Sent: Saturday, April 17, 2021 7:07 AM
To: Mark Rivers
Cc: EPICS Tech-Talk
Subject: Re: WIN_32
On 4/16/21 5:44 PM, Mark Rivers wrote:
EPICS_BASE_PVA_CORE_LIBS = pvDatabase pvAccess pvAccessCA pvData
pvaClient Com
Mark,
I made that change.
The pull request still fails for windows and rtems.
Does it build for You on windows?
Marty
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
RE: WIN_32 Freddie Akeroyd - STFC UKRI via Tech-talk
WIN_32 Marty Kraimer via Tech-talk
RE: WIN_32 Mark Rivers via Tech-talk
Re: WIN_32 Marty Kraimer via Tech-talk
Re: WIN_32 Mark Rivers via Tech-talk
Prev: Re: PVA crossing network segments Michael Davidsaver via Tech-talk
Next: RE: WIN_32 Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: WIN_32 Mark Rivers via Tech-talk
ANJ, 17 Apr 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
