1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: WIN_32
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: Marty Kraimer <[email protected]>
Cc: tech talk <[email protected]>
Date: Sat, 17 Apr 2021 22:09:40 +0000
Hi Marty,
It looks like at some point I created a "linux-x86_64-static" EPICS host arch config on our system that set:
STATIC_BUILD = YES
SHARED_LIBRARIES = NO
I think that the default EPICS linux build creates both shared and archive libraries, but the shared ones may get preferred over archive libraries during linking.
There are two travis windows builds, one for DLL linking and one for static linking. I see that the windows build is actually a MinGW/Wine cross compile on Ubuntu - I think some of the library order issues you are seeing may be an artefact of this. I believe the linux static linker only makes one pass, but the windows linker always make multiple passes, so you may see issues with the cross compile that would not occur on native windows - however I think they would still occur when linking statically for a linux target
Freddie
> -----Original Message-----
> From: Marty Kraimer <[email protected]>
> Sent: 17 April 2021 22:34
> To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
> Subject: Re: WIN_32
> On 4/17/21 4:54 PM, Freddie Akeroyd - STFC UKRI wrote:
> > Hi Marty,
> > Do you also build your programs linked statically on linux too? If
> > not, it might be worth doing that too - I believe any purely link
> > order issues you may see with travis windows should also occur when
> > linking statically on linux
> > Regards,
> > Freddie
> How do I do this on Linux?
> I also have a couple of questions about the travis  builds.
> 1) Why are there two sets of builds,
> 2) Do  any of the gcc or clang builds statically linked.
> Marty
> >> From: Tech-talk <[email protected]> On Behalf Of Mark
> >> Rivers via Tech-talk
> >> Sent: 17 April 2021 13:37
> >> Cc: EPICS Tech-Talk <[email protected]>
> >> Subject: Re: WIN_32
> >> Hi Marty,
> >> You are making progress, the error is now different:
> >> /home/travis/.source/pvaClient/lib/linux-x86_64/libpvaClient.a(pvaCli
> >> ent.o): In function `epics::pvaClient::PvaClient::~PvaClient()':
> >> /home/travis/.source/pvaClient/src/O.linux-x86_64/../pvaClient.cpp:156:
> >> undefined reference to `epics::pvAccess::ClientFactory::stop()'
> >> So now a function in pvaClient is not finding the pvAccess functions.
> >> That is probably a link order problem.
> >> Try this:
> >> EPICS_BASE_PVA_CORE_LIBS =  pvaClient  pvDatabase pvAccess pvAccessCA
> >> pvData Com
> >> Or leave EPICS_BASE_PVA_CORE_LIBS as it was originally and add
> >> pvaClient
> >> here:
> >> PROD_HOST += serviceMain
> >> serviceMain_SRCS += serviceMain.cpp
> >> serviceMain_LIBS += controlRecord
> >> serviceMain_LIBS += powerSupplyRecord serviceMain_LIBS += linkRecord
> >> serviceMain_LIBS += pvaClient serviceMain_LIBS +=
> >> $(EPICS_BASE_PVA_CORE_LIBS)
> >> Mark
> >> ________________________________
> >> Sent: Saturday, April 17, 2021 7:07 AM
> >> To: Mark Rivers
> >> Cc: EPICS Tech-Talk
> >> Subject: Re: WIN_32
> >> On 4/16/21 5:44 PM, Mark Rivers wrote:
> >>> EPICS_BASE_PVA_CORE_LIBS = pvDatabase pvAccess pvAccessCA pvData
> >> pvaClient Com
> >> Mark,
> >> I made that change.
> >> The pull request still fails for windows and rtems.
> >> Does it build for You on windows?
> >> Marty
> > This email and any attachments are intended solely for the use of the named
> recipients. If you are not the intended recipient you must not use, disclose,
> copy or distribute this email or any of its attachments and should notify the
> sender immediately and delete this email from your system. UK Research and
> Innovation (UKRI) has taken every reasonable precaution to minimise risk of
> this email or any attachments containing viruses or malware but the recipient
> should carry out its own virus and malware checks before opening the
> attachments. UKRI does not accept any liability for any losses or damages
> which the recipient may sustain due to presence of any viruses. Opinions,
> conclusions or other information in this message and attachments that are not
> related directly to UKRI business are solely those of the author and do not
> represent the views of UKRI.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
WIN_32 Marty Kraimer via Tech-talk
RE: WIN_32 Mark Rivers via Tech-talk
Re: WIN_32 Marty Kraimer via Tech-talk
Re: WIN_32 Mark Rivers via Tech-talk
Prev: Re: WIN_32 Marty Kraimer via Tech-talk
Next: pv Access setup Дмитрий Прощенко via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: WIN_32 Marty Kraimer via Tech-talk
