Hi, Mark Thank you for your reply
Before this error occurred, I had the below error.
make -C O.linux-arm -f ../Makefile TOP=../../.. \ T_A=linux-arm install make[1]: Entering directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm' make[1]: *** No rule to make target '../../../lib/linux-arm/libX11.a', needed by 'alh'. Stop. make[1]: Leaving directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm' make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2
So I confirmed the location of libX11.a and copied this file(
/usr/lib/arm-linux-gnueabihf/libX11.a ) to /home/pi/epics/base-3.15.8/lib/linux-arm/.
pi@raspberrypi:~/epics/extensions/src/alh1_2_35 $ locate libX11.a /usr/lib/arm-linux-gnueabihf/libX11.a
Ryu
Hi Ryu,
I have not worked with linux-arm, so I may be off base.
Error messages like this:
/usr/bin/ld: /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a(CrGlCur.o): undefined reference to symbol 'dlopen@@GLIBC_2.4'
often mean that the version of gcc (which supplies GLBIC) is older than the version required by a library you are using.
Where did you get this file? /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a
That seems like an unusual location for the X11 library file.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Huyn Woo Ryu via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, April 27, 2021 4:51 AM
To: tech-talk at aps.anl.gov
Subject: how to install alh on raspberry pi 4
Hi,I installed base-3.15.8 successfully on raspberry piBut when I install 'alh1_2_35' on raspberry pi OS(kernel version 5.10) on raspberry pi 4, it can't make successfully, the err as follows:
/usr/bin/ld: //lib/arm-linux-gnueabihf/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [../../../../base/configure/RULES_BUILD:204: alh] Error 1
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2 I don't know how to fix it, could you give me some advice on it?Please, Help me! I consumed many time for this problem.Ryu
- how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
- Re: how to install alh on raspberry pi 4 Mark Rivers via Tech-talk
- Re: how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
<2021>
2025
<2021>
2025
ANJ, 27 Apr 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
