1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: how to install alh on raspberry pi 4
From: Huyn Woo Ryu via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 30 Apr 2021 11:55:47 +0900
Hi Mark
Thanks to your kind help, I finally resolved  this error.
Below I summarized what I did
1. To copy CONFIG_SITE.linux-x86.linux-x86 as CONFIG_SITE.linux-arm.linux-arm.
2. To edit next items.
    X11_LIB=/usr/lib -->X11_LIB=/usr/lib/arm-linux-gnueabihf
    MOTIF_LIB=/usr/lib -->MOTIF_LIB=/usr/lib/arm-linux-gnueabihf
3. To compile
pi@raspberrypi:~/epics/extensions/src/alh1_2_35 $ sudo make
   Installing created executable ../../../bin/linux-arm/alh
mkdir ../../../bin
mkdir ../../../bin/linux-arm
Installing created executable ../../../bin/linux-arm/alh_printer
Installing created executable ../../../bin/linux-arm/alh_DB
make[1]: Leaving directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm'
Successfully  installed without error.
Thank you very much for your help.
On Wed, Apr 28, 2021 at 9:48 PM Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Ryu,
Ø   there in no CONFIG_SITE.linux-arm.linux-arm as you see like below list
Then you will need to add one.  You can use CONFIG_SITE.linux-x86_64.linux-x86_64 as your model.
Ø  2. and below the list is the output of the command you requested.
Ø  pi@raspberrypi:~/epics/extensions/src $ ldd /usr/lib/arm-linux-gnueabihf/libX11.so
linux-vdso.so.1 (0xbe968000)
That looks fine.  When you build it will link with that .so file, and not the .a file.
Ø  3. there is no header file of libX11 library  to set  X11_INC variable .
There is no include file is not called libX11.h.  There should be an entire directory with X11 include files.  This is what I find on my Centos 7 system.
corvette:~/devel/dante>ls /usr/include/X11
CallbackI.h   Core.h       HookObjI.h    IntrinsicP.h  RectObjP.h    ShellI.h      VarargsI.h    XWDFile.h  Xcursor       Xlib.h      Xos.h        Xregion.h    Xwindows.h    extensions
Composite.h   CoreP.h      ICE           Object.h      ResConfigP.h  ShellP.h      Vendor.h      Xalloca.h  Xdefs.h       XlibConf.h  Xos_r.h      Xresource.h  Xwinsock.h    fonts
CompositeP.h  CreateI.h    ImUtil.h      ObjectP.h     ResourceI.h   StringDefs.h  VendorP.h     Xarch.h    Xft           Xlibint.h   Xosdefs.h    Xthreads.h   ap_keysym.h   keysym.h
ConstrainP.h  DECkeysym.h  InitialI.h    PM            SM            Sunkeysym.h   X.h           Xatom.h    Xfuncproto.h  Xlocale.h   Xpoll.h      Xtos.h       bitmaps       keysymdef.h
Constraint.h  EventI.h     Intrinsic.h   PassivGraI.h  SelectionI.h  ThreadsI.h    XF86keysym.h  Xauth.h    Xfuncs.h      Xmd.h       Xproto.h     Xutil.h      cursorfont.h
ConvertI.h    HPkeysym.h   IntrinsicI.h  RectObj.h     Shell.h       TranslateI.h  XKBlib.h      Xcms.h     Xlib-xcb.h    Xmu         Xprotostr.h  Xw32defs.h   dri
You need to find the equivalent directory on your system and define X11_INC to point to it.
Sent: Wednesday, April 28, 2021 2:20 AM
To: Mark Rivers
Cc: tech-talk at aps.anl.gov
1. there in no CONFIG_SITE.linux-arm.linux-arm as you see like below list
pi@raspberrypi:~/epics/extensions/configure $ ls os/
CONFIG.linux-x86.linux-386                         CONFIG_SITE.linux-x86.linux-athlon
CONFIG_SITE.aix-ppc.aix-ppc                        CONFIG_SITE.linux-x86.linux-x86
CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu                CONFIG_SITE.osf-alpha.osf-alpha
CONFIG_SITE.Common.Common                          CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
CONFIG_SITE.cygwin-x86.cygwin-x86                  CONFIG_SITE.solaris-sparc64.solaris-sparc64
CONFIG_SITE.darwin-ppc.darwin-ppc                  CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
CONFIG_SITE.darwin-ppcx86.darwin-ppcx86            CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
CONFIG_SITE.darwin-x86.darwin-x86                  CONFIG_SITE.solaris-sparc.solaris-sparc
CONFIG_SITE.freebsd-x86_64.freebsd-x86_64          CONFIG_SITE.solaris-sparc.solaris-sparc64
CONFIG_SITE.freebsd-x86.freebsd-x86                CONFIG_SITE.solaris-x86_64.solaris-x86_64
CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu        CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
CONFIG_SITE.hpux-parisc.hpux-parisc                CONFIG_SITE.solaris-x86.solaris-x86
CONFIG_SITE.interix-x86.interix-x86                CONFIG_SITE.solaris-x86.solaris-x86_64
CONFIG_SITE.linux-ppc.linux-ppc                    CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin
CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug  CONFIG_SITE.win32-x86-debug.win32-x86-debug
CONFIG_SITE.linux-x86_64.linux-x86_64              CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
CONFIG_SITE.linux-x86-debug.linux-x86-debug        CONFIG_SITE.win32-x86.win32-x86
/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0xb6df2000)
libxcb.so.1 => /lib/arm-linux-gnueabihf/libxcb.so.1 (0xb6dad000)
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb6d9a000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6c4c000)
/lib/ld-linux-armhf.so.3 (0xb6f29000)
libXau.so.6 => /lib/arm-linux-gnueabihf/libXau.so.6 (0xb6c39000)
libXdmcp.so.6 => /lib/arm-linux-gnueabihf/libXdmcp.so.6 (0xb6c24000)
libbsd.so.0 => /lib/arm-linux-gnueabihf/libbsd.so.0 (0xb6bfc000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0xb6be5000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6bbb000)
pi@raspberrypi:~/epics/extensions/src $ locate libX11
/usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1
/usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1.0.0
/usr/lib/arm-linux-gnueabihf/libX11.a
/usr/lib/arm-linux-gnueabihf/libX11.so.6
/usr/lib/arm-linux-gnueabihf/libX11.so.6.3.0
On Wed, Apr 28, 2021 at 10:31 AM Mark Rivers <rivers at cars.uchicago.edu> wrote:
> So I confirmed the location of libX11.a and  copied this file( /usr/lib/arm-linux-gnueabihf/libX11.a ) to  /home/pi/epics/base-3.15.8/lib/linux-arm/.
That is definitely not the right way to do it.
In epics/extensions/configure/os you need to edit the correct CONFIG_SITE.* file to define the location of X11. For example CONFIG_SITE.linux-x86_64.linux-x86_64 on my system contains these lines:
X11_LIB=/usr/lib64
X11_INC=/usr/include
# OpenMotif location
MOTIF_LIB=/usr/lib64
MOTIF_INC=/usr/include
You need to define the X11_LIB and X11_INC directories for your system.
But I am not sure that will fix your problem.  Do you only have the static library /usr/lib/arm-linux-gnueabihf/libX11.a, or do you also have the dynamic library libX11.so?  If you do have the libX11.so file, then please send the output of this command:
ldd libX11.so
Sent: Tuesday, April 27, 2021 7:19 PM
To: Mark Rivers
Hi, Mark
Thank you for your reply
Before this error occurred, I had the below error.
make -C O.linux-arm -f ../Makefile TOP=../../.. \
    T_A=linux-arm install
make[1]: Entering directory '/home/pi/epics/extensions/src/alh1_2_35/O.linux-arm'
make[1]: *** No rule to make target '../../../lib/linux-arm/libX11.a', needed by 'alh'.  Stop.
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2
pi@raspberrypi:~/epics/extensions/src/alh1_2_35 $ locate libX11.a
On Tue, Apr 27, 2021 at 8:42 PM Mark Rivers <rivers at cars.uchicago.edu<mailto:rivers at cars.uchicago.edu>> wrote:
Hi Ryu,
I have not worked with linux-arm, so I may be off base.
Error messages like this:
/usr/bin/ld: /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a(CrGlCur.o): undefined reference to symbol 'dlopen@@GLIBC_2.4'
often mean that the version of gcc (which supplies GLBIC) is older than the version required by a library you are using.
 Where did you get this file?   /home/pi/epics/base-3.15.8/lib/linux-arm/libX11.a
That seems like an unusual location for the X11 library file.
From: Tech-talk <tech-talk-bounces at aps.anl.gov<mailto:tech-talk-bounces at aps.anl.gov>> on behalf of Huyn Woo Ryu via Tech-talk <tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov>>
Sent: Tuesday, April 27, 2021 4:51 AM
To: tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov>
Subject: how to install alh on raspberry pi 4
 Hi,I installed base-3.15.8 successfully on raspberry piBut when I install 'alh1_2_35' on raspberry pi OS(kernel version 5.10) on raspberry pi 4, it can't make successfully, the err as follows:
/usr/bin/ld: //lib/arm-linux-gnueabihf/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [../../../../base/configure/RULES_BUILD:204: alh] Error 1
make: *** [../../../base/configure/RULES_ARCHS:58: install.linux-arm] Error 2   I don't know how to fix it, could you give me some advice on it?Please, Help me! I consumed many time for this problem.Ryu
how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
Re: how to install alh on raspberry pi 4 Mark Rivers via Tech-talk
Re: how to install alh on raspberry pi 4 Huyn Woo Ryu via Tech-talk
Prev: Re: [EXTERNAL] Question about image widget in Phoebus Florian Feldbauer via Tech-talk
Next: ADVimba disconnect John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: how to install alh on raspberry pi 4 Mark Rivers via Tech-talk
Next: Pointing an IOC to system-level lib files for build Katie Matusik via Tech-talk
ANJ, 30 Apr 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
