1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: asynSetTrace
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 11 May 2021 12:30:14 +0200
Hi Petra,
First of all:
Which version of asyn are you using?
Any particular reason for using an older EPICS 7 version, not the latest release of that branch? (Not that it would change anything for this particular issue, but...)
On Tue, 11 May 2021 at 12:02, Petra Schwalbach via Tech-talk <[email protected]> wrote:
I want to use
asynSetTraceMask(portName,addr,mask)
asynSetTraceIOMask(portName,addr,mask)
I used EPICS 3.14.12.5 and I had no problems.
Now I use EPICS -7.0.3.1.
I configured my IOC like described in
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/creating-ioc.html
I add
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
to st.cmd, but nothing happens.
Does the command "help" on the IOC console show these commands? (That's always a quick check if things have been registered properly.)
Do you have an existing asyn port with that name correctly configured?
If yes to both: Are you sure that something is happening on that port? Do you have records connected that are working?
Cheers,
~Ralph
asynSetTrace Petra Schwalbach via Tech-talk
Prev: asynSetTrace Petra Schwalbach via Tech-talk
Next: Re: asynSetTrace Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
