1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: asynSetTrace
To: Petra Schwalbach <[email protected]>
Date: Tue, 11 May 2021 12:09:02 +0000
Hi Petra,
If you configured your IOC as shown in that document then it should not matter which version of base you are running.
> I add
> asynSetTraceIOMask("L0",-1,0x2)
> asynSetTraceMask("L0",-1,0x9)
> to st.cmd, but nothing happens.
By "nothing happens" does that mean you got an error message when those asynSetTrace commands were executed, or just that there was no output from asynTrace.
Can you send the complete output when the IOC starts up and runs for several seconds?
From: Tech-talk <[email protected]> on behalf of Petra Schwalbach via Tech-talk <[email protected]>
Sent: Tuesday, May 11, 2021 5:02 AM
To: Mark Rivers via Tech-talk
Subject: asynSetTrace
Hello,
I want to use
asynSetTraceMask(portName,addr,mask)
asynSetTraceIOMask(portName,addr,mask)
I used EPICS 3.14.12.5 and I had no problems.
Now I use EPICS -7.0.3.1.
I configured my IOC like described in
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/creating-ioc.html<https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/creating-ioc.html?highlight=trace#creation-of-an-input-output-controller-ioc>
I add
My IOC is working.
Could it be that there is something to add to the xxxSupport.dbd file
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
something like registrar(drvAsynSetTraceCommands)?
Thank you for your efforts!
Best regards
Petra
Petra Schwalbach                            [email protected]<Petra%20Schwalbach>
Privat:
mobil 0151 58854122
Festnetz 06131 593275
Inst. f. Kernphysik, Uni Mainz          Tel.: 06131/39-25193
B1-Kollaboration                               Fax: 06131/39-22964
Johann-Joachim-Becher-Weg 45     http://portal.kph.uni-mainz.de/B1/
55099 Mainz
asynSetTrace Petra Schwalbach via Tech-talk
Prev: Re: asynSetTrace Ralph Lange via Tech-talk
Next: RE: asynSetTrace Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
