1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: RE: AreaDetector FrameType
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: 'David Vine' <dvine at sigray.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 12 May 2021 16:51:07 +0000
Hi David,
Ø  But i can't find a description for how to use it in the docs or the code.
ADFrameType is used to tell the driver what type of frame to collect: normal, background, flat field, etc.  This is mainly used by drivers that can perform the background and/or flat-field corrections in the vendor SDK, often using an FPGA.
There appear to be 6 drivers that currently use ADFrameType.  This is a list of those drivers determined using “find”.
corvette:~/devel/areaDetector>find . -name '*.cpp' -exec grep -H FrameType {} \;
./ADDexela/dexelaApp/src/Dexela.cpp:    getIntegerParam(ADFrameType,         &frameType);
./ADDexela/dexelaApp/src/Dexela.cpp:    setIntegerParam(ADFrameType, ADFrameNormal);
./ADDexela/dexelaApp/src/Dexela.cpp:    setIntegerParam(ADFrameType, ADFrameBackground);
./ADDexela/dexelaApp/src/Dexela.cpp:    setIntegerParam(ADFrameType, ADFrameFlatField);
./ADBruker/brukerApp/src/BISDetector.cpp:        getIntegerParam(ADFrameType, &frameType);
./ADPixirad/pixiradApp/src/pixirad.cpp:    status |= setIntegerParam(ADFrameType, FTOneColorLow);
./ADPixirad/pixiradApp/src/pixirad.cpp:    getIntegerParam(ADFrameType, &frameType);
./ADPixirad/pixiradApp/src/pixirad.cpp:    } else if ((function == ADFrameType) ||
./ADPCO/pcoApp/src/pco.cpp:  if (getIntParam(ADFrameType) == ADFrameNormal)  // normal
./ADPCO/pcoApp/src/pco.cpp:  else if (getIntParam(ADFrameType) == ADFrameBackground)  // dark
./ADPCO/pcoApp/src/pco.cpp:  else if (getIntParam(ADFrameType) == ADFrameFlatField)  // white flood
./ADmarCCD/marCCDApp/src/marCCD.cpp:    getIntegerParam(ADFrameType, &frameType);
./ADPhotonII/PhotonIIApp/src/PhotonII.cpp:        getIntegerParam(ADFrameType, &frameType);
The Dexela and marCCD drivers are probably the best ones to look at.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of David Vine via Tech-talk
Sent: Wednesday, May 12, 2021 11:11 AM
To: tech-talk at aps.anl.gov
Subject: AreaDetector FrameType
Hi all,
I see the frame type enum definition in ADCore:
typedef enum
    ADFrameNormal,          /**< Normal frame type */
    ADFrameBackground,      /**< Background frame type */
    ADFrameFlatField,       /**< Flat field (no sample) frame type */
    ADFrameDoubleCorrelation      /**< Double correlation frame type, used to remove zingers */
} ADFrameType_t
Could someone point me to the documentation or an example?
David
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Re: AreaDetector FrameType Jemian, Pete R. via Tech-talk
AreaDetector FrameType David Vine via Tech-talk
Prev: AreaDetector FrameType David Vine via Tech-talk
Next: Re: AreaDetector FrameType Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
ANJ, 12 May 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
