Hi all,
I see the frame type enum definition in ADCore: typedef enum { ADFrameNormal, /**< Normal frame type */ ADFrameBackground, /**< Background frame type */ ADFrameFlatField, /**< Flat field (no sample) frame type */ ADFrameDoubleCorrelation /**< Double correlation frame type, used to remove zingers */ } ADFrameType_t
But i can't find a description for how to use it in the docs or the code.
Could someone point me to the documentation or an example?
Thanks, David
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
- RE: AreaDetector FrameType Mark Rivers via Tech-talk
RE: Building ADSupport with external libxml2 Heesterman, Peter J via Tech-talk
<2021>
2025
New Docker images for base 7.0.5, synApps 6.2, AD 3.10 Jemian, Pete R. via Tech-talk
<2021>
2025
ANJ, 12 May 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
