1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Utilizing StreamDevice in conjunction with sockets
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: "Pogge, James Robert" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 18 May 2021 15:09:07 +0000
Hi Andy,
On May 17, 2021, at 9:04 PM, Wang, Andrew via Tech-talk <[email protected]> wrote:
Is it possible you could give a quick and abridged summary of how to use asynTrace? I added it to my st.cmd, but not sure what I should be seeing.
The asynTrace facility allows you to turn on logging of various different kinds of information that passes through Asyn on a per-port basis. The API used by the driver code should give you some idea of its capabilities and is documented here:
If you want to see how it can be used you could do a search through the tech-talk archives, turning on tracing is something that Mark very frequently asks people to do to help them debug their systems, so there are many examples there.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Utilizing StreamDevice in conjunction with sockets Wang, Andrew via Tech-talk
Re: Utilizing StreamDevice in conjunction with sockets Mark Rivers via Tech-talk
RE: Utilizing StreamDevice in conjunction with sockets Wang, Andrew via Tech-talk
RE: Utilizing StreamDevice in conjunction with sockets Mark Rivers via Tech-talk
Prev: Re: Archiver Appliance mgmt tomcat issue Shankar, Murali via Tech-talk
Next: Re: Archiver Appliance mgmt tomcat issue Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Utilizing StreamDevice in conjunction with sockets Wang, Andrew via Tech-talk
Next: RE: Utilizing StreamDevice in conjunction with sockets Mark Rivers via Tech-talk
