1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Archiver Appliance mgmt tomcat issue
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Tue, 18 May 2021 13:17:15 +0000
>> When I try to get the web page to serve up on another PC that is not on the same subnet 192.168.2.25(PC) and 192.168.3.50(Archiver) for example it seems like the request gets stuck.
To see if it is a networking thing; you could use "curl -v"  to connect to http://192.168.3.50:17665/mgmt/ui/index.html or telnet to connect to 192.168.3.50 17665 from the 192.168.2.25(PC).
>> Some possible debugging has led to the JS not being loaded properly on the web browsers
You can look in the mgmt's localhost access logs to see if there is a difference when loading the UI from the local machine to the PC. Both Firefox and Chrome also should have more details in the Browser console; you should be able to see any Exceptions there.
>> I wasn’t sure about the redirectPort if that had to be changed?
Not really; not unless you plan to use HTTPS for the tomcats.
Hope this helps.
Murali
RE: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Prev: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Next: Re: Utilizing StreamDevice in conjunction with sockets Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Next: RE: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
