1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Archiver Appliance mgmt tomcat issue
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 13 Aug 2021 04:19:20 +0000
Thanks Murali, ive been busy getting a bunch of other things running but will need to revisit this in the future.  Will try out some of your suggestions when I get a chance.
Adam
From: Tech-talk <[email protected]> On Behalf Of Shankar, Murali via Tech-talk
Sent: Tuesday, May 18, 2021 6:17 AM
To: [email protected]
Subject: Re: Archiver Appliance mgmt tomcat issue
>> When I try to get the web page to serve up on another PC that is not on the same subnet 192.168.2.25(PC) and 192.168.3.50(Archiver) for example it seems like the request gets stuck.
To see if it is a networking thing; you could use "curl -v"  to connect to http://192.168.3.50:17665/mgmt/ui/index.html or telnet to connect to 192.168.3.50 17665 from the 192.168.2.25(PC).
>> Some possible debugging has led to the JS not being loaded properly on the web browsers
You can look in the mgmt's localhost access logs to see if there is a difference when loading the UI from the local machine to the PC. Both Firefox and Chrome also should have more details in the Browser console; you should be able to see any Exceptions there.
>> I wasn’t sure about the redirectPort if that had to be changed?
Not really; not unless you plan to use HTTPS for the tomcats.
Hope this helps.
Murali
Re: Archiver Appliance mgmt tomcat issue Shankar, Murali via Tech-talk
Prev: Re: Mark Rivers via Tech-talk
Next: IOC PVA on mTCA CPU requires environment variables to be set Meeus Kris via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Archiver Appliance mgmt tomcat issue Shankar, Murali via Tech-talk
Next: New sequencer release 2.2.9 Ben Franksen via Tech-talk
