1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: EPICS stopped
From: "Tagger, Jueri via Tech-talk" <[email protected]>
Date: Wed, 19 May 2021 17:16:47 +0000
Thanks to all for many good advices!
Juri
Kay wrote:
Well, good.
I would post that to tech talk, maybe somebody has an idea what's happening.
Or at least there's now a record in case it happens again.
Sure looks like several threads are stuck waiting for a semaphore:
Thread 84 (Thread 0x7f39b98b8700 (LWP 66431)):
#0  __lll_lock_wait () at ../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:135
#1  0x00007f3a03c74494 in _L_lock_952 () from /lib/x86_64-linux-gnu/libpthread.so.0
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978038770) at ../nptl/pthread_mutex_lock.c:114
#3  0x00007f3a04a99fb6 in epicsMutexOsdLock () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a04f8887d in casAccessRightsCB () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04a76f7e in asComputePvt.part.1 () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#6  0x00007f3a04a77127 in asComputeAsgPvt.part.2 () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#7  0x00007f3a04a77868 in asComputeAsg () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#8  0x00007f3a04d10bc0 in oldSubscription::current(epicsGuard<epicsMutex>&, unsigned int, unsigned long, void const*) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#9  0x00007f3a04cef017 in cac::eventRespAction(callbackManager&, tcpiiu&, epicsTime const&, caHdrLargeArray const&, void*) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#10 0x00007f3a04d07616 in tcpiiu::processIncoming(epicsTime const&, callbackManager&) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#11 0x00007f3a04d098aa in tcpRecvThread::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#12 0x00007f3a04a92089 in epicsThreadCallEntryPoint () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#13 0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#14 0x00007f3a03c72064 in start_thread (arg=0x7f39b98b8700) at pthread_create.c:309
#15 0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
--> Trying to re-compute access security?
Thread 142 (Thread 0x7f3a0222f700 (LWP 453879)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x1771580) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f4c01b in dbScanLock () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f5cbdc in scanList () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04f5cd2f in ioscanCallback () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04f66e05 in callbackTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#8  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#9  0x00007f3a03c72064 in start_thread (arg=0x7f3a0222f700) at pthread_create.c:309
#10 0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
--> Trying to scan some record?
#5  0x00007f3a04f647d1 in dbChannel_get_count () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04f8ad52 in read_notify_action () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04f8b72e in camessage () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#8  0x00007f3a04f881e3 in camsgtask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#9  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#10 0x00007f3a03c72064 in start_thread (arg=0x7f394adf3700) at pthread_create.c:309
#11 0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
--> Trying to reply to a CA read, about to lock the channel to get the data size (element count)?
-Kay
Sent: Wednesday, May 19, 2021 12:19 PM
To: Tagger, Jueri <[email protected]>
Cc: [email protected]
Is this Linux or some other OS?
It looks like you will need to kill the IOC process.
Sent: Wednesday, May 19, 2021 11:15 AM
No effect from ^C whatsoever. Typed epicsMutexShowAll 1
3 times to blank screen – no response
Sent: Wednesday, May 19, 2021 12:12 PM
Can you type ^C to abort the casr command?  It could be a deadlock.  If that works then type
epicsMutexShowAll 1
several times and see if the same mutexes are always locked.   That is the symptom of a deadlock.
From: Tech-talk <[email protected]> On Behalf Of Tagger, Jueri via Tech-talk
Sent: Wednesday, May 19, 2021 11:04 AM
To: [email protected]
Subject: EPICS stopped
We have suddenly situation we can no longer connect to ca channels, (while the existing connections are served)
casr 4
181888 bytes allocated
       Send Lock:
           epicsMutexId 0x7f3978036420 source ../../../src/ioc/rsrv/caservertask.c line 1231
       Put Notify Lock:
           epicsMutexId 0x7f3978036450 source ../../../src/ioc/rsrv/caservertask.c line 1232
       Address Queue Lock:
           epicsMutexId 0x7f3978036480 source ../../../src/ioc/rsrv/caservertask.c line 1233
       Event Queue Lock:
           epicsMutexId 0x7f39780364b0 source ../../../src/ioc/rsrv/caservertask.c line 1234
       Block Semaphore:
           epicsEvent 0x7f3978010c90: full
    pthread_mutex = 0x7f3978010c90, pthread_cond = 0x7f3978010cb8
    TCP client at 10.0.153.12:54302 'box64-3':
       User 'rose', V4.13, Priority = 0, 75 Channels
       Task Id = 0x7f397803c750, Socket FD = 44
       2262.05 secs since last send, 2262.04 secs since last receive
       Unprocessed request bytes = 424, Undelivered response bytes = 0
       State = up
Then the output stopped …. no response any more on the console
EPICS_BASE=base-3.15.8
Any ideas?
J. Tagger
NSLS-II=
Thread 146 (Thread 0x7f3a06b70700 (LWP 453870)):
#0  pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S:185
#1  0x00007f3a04a9a47b in epicsEventWait () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#2  0x00007f3a04a934c9 in epicsEventMustWait () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04a819e5 in errlogThread () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a06b70700) at pthread_create.c:309
#6  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 145 (Thread 0x7f3a06aef700 (LWP 453872)):
#0  pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238
#1  0x00007f3a04a9a609 in epicsEventWaitWithTimeout () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#2  0x00007f3a04a9339c in epicsEvent::wait(double) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04aa2f15 in timerQueueActive::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a04a92089 in epicsThreadCallEntryPoint () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#5  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#6  0x00007f3a03c72064 in start_thread (arg=0x7f3a06aef700) at pthread_create.c:309
#7  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 144 (Thread 0x7f3a023b1700 (LWP 453877)):
#2  0x00007f3a04a9ffe4 in twdTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f3a023b1700) at pthread_create.c:309
#5  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 143 (Thread 0x7f3a02330700 (LWP 453878)):
#6  0x00007f3a03c72064 in start_thread (arg=0x7f3a02330700) at pthread_create.c:309
Thread 141 (Thread 0x7f3a0202e700 (LWP 453880)):
#3  0x00007f3a04f66e39 in callbackTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a0202e700) at pthread_create.c:309
Thread 140 (Thread 0x7f3a01e2d700 (LWP 453881)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a01e2d700) at pthread_create.c:309
Thread 139 (Thread 0x7f3a01c2c700 (LWP 453882)):
#3  0x00007f3a04f684fc in dbCaTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a01c2c700) at pthread_create.c:309
Thread 138 (Thread 0x7f3a01a2b700 (LWP 453883)):
#0  0x00007f3a03f40f2d in nanosleep () at ../sysdeps/unix/syscall-template.S:81
#1  0x00007f3a04a98d70 in epicsThreadSleep () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#2  0x00007f3a0677b379 in s7plcMain () from /epics/iocs/SR-Cry/lib/linux-x86_64/libsrCrySupport.so
#4  0x00007f3a03c72064 in start_thread (arg=0x7f3a01a2b700) at pthread_create.c:309
Thread 137 (Thread 0x7f3a0182a700 (LWP 453884)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x182b0e0) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f855f9 in casStatsFetch () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a05c37e29 in scan_time () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/iocStats/lib/linux-x86_64/libdevIocStats.so
#6  0x00007f3a04aa107e in epicsTimerForC::expire(epicsTime const&) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#7  0x00007f3a04aa27be in timerQueue::process(epicsTime const&) () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#8  0x00007f3a04aa2f09 in timerQueueActive::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#9  0x00007f3a04a92089 in epicsThreadCallEntryPoint () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#10 0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#11 0x00007f3a03c72064 in start_thread (arg=0x7f3a0182a700) at pthread_create.c:309
#12 0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 136 (Thread 0x7f3a01729700 (LWP 453885)):
#0  0x00007f3a03f68893 in select () at ../sysdeps/unix/syscall-template.S:81
#1  0x00007f3a0677baca in s7plcReceiveThread () from /epics/iocs/SR-Cry/lib/linux-x86_64/libsrCrySupport.so
#2  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a01729700) at pthread_create.c:309
#4  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 135 (Thread 0x7f3a01528700 (LWP 453886)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a01528700) at pthread_create.c:309
Thread 134 (Thread 0x7f3a01327700 (LWP 453887)):
#3  0x00007f3a0677be6c in s7plcSendThread () from /epics/iocs/SR-Cry/lib/linux-x86_64/libsrCrySupport.so
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a01327700) at pthread_create.c:309
Thread 133 (Thread 0x7f3a01126700 (LWP 453888)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a01126700) at pthread_create.c:309
Thread 132 (Thread 0x7f3a00f25700 (LWP 453889)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a00f25700) at pthread_create.c:309
Thread 131 (Thread 0x7f3a00d24700 (LWP 453890)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a00d24700) at pthread_create.c:309
Thread 130 (Thread 0x7f3a00b23700 (LWP 453891)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a00b23700) at pthread_create.c:309
Thread 129 (Thread 0x7f3a00922700 (LWP 453892)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a00922700) at pthread_create.c:309
Thread 128 (Thread 0x7f3a00721700 (LWP 453893)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a00721700) at pthread_create.c:309
Thread 127 (Thread 0x7f3a00520700 (LWP 453894)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3a00520700) at pthread_create.c:309
Thread 126 (Thread 0x7f3a0031f700 (LWP 453895)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a0031f700) at pthread_create.c:309
Thread 125 (Thread 0x7f39bbfff700 (LWP 453896)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39bbfff700) at pthread_create.c:309
Thread 124 (Thread 0x7f39bbdfe700 (LWP 453897)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39bbdfe700) at pthread_create.c:309
Thread 123 (Thread 0x7f39bbbfd700 (LWP 453898)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39bbbfd700) at pthread_create.c:309
Thread 122 (Thread 0x7f39bb9fc700 (LWP 453899)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39bb9fc700) at pthread_create.c:309
Thread 121 (Thread 0x7f39bb7fb700 (LWP 453900)):
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39bb7fb700) at pthread_create.c:309
Thread 120 (Thread 0x7f39bb5fa700 (LWP 453901)):
#3  0x00007f3a04f5cd90 in onceTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39bb5fa700) at pthread_create.c:309
Thread 119 (Thread 0x7f39bb3f9700 (LWP 453902)):
#2  0x00007f3a04f5cebb in periodicTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39bb3f9700) at pthread_create.c:309
Thread 118 (Thread 0x7f39bb1f8700 (LWP 453903)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39bb1f8700) at pthread_create.c:309
Thread 117 (Thread 0x7f39baff7700 (LWP 453904)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39baff7700) at pthread_create.c:309
Thread 116 (Thread 0x7f39badf6700 (LWP 453905)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39badf6700) at pthread_create.c:309
Thread 115 (Thread 0x7f39babf5700 (LWP 453906)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39babf5700) at pthread_create.c:309
Thread 114 (Thread 0x7f39ba9f4700 (LWP 453907)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39ba9f4700) at pthread_create.c:309
Thread 113 (Thread 0x7f39ba7f3700 (LWP 453908)):
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39ba7f3700) at pthread_create.c:309
Thread 112 (Thread 0x7f39ba5f2700 (LWP 453916)):
#3  0x00007f3a04f4aeb4 in asCaTask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39ba5f2700) at pthread_create.c:309
Thread 111 (Thread 0x7f39ba3f1700 (LWP 453917)):
#2  0x00007f3a04a9334c in epicsEvent::wait() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04a8fbb2 in (anonymous namespace)::ipAddrToAsciiGlobal::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#6  0x00007f3a03c72064 in start_thread (arg=0x7f39ba3f1700) at pthread_create.c:309
Thread 110 (Thread 0x7f3a0011e700 (LWP 453918)):
#6  0x00007f3a03c72064 in start_thread (arg=0x7f3a0011e700) at pthread_create.c:309
Thread 109 (Thread 0x7f39b99b9700 (LWP 453919)):
#0  0x00007f3a03f70543 in recvfrom () at ../sysdeps/unix/syscall-template.S:81
#1  0x00007f3a04d0226c in udpRecvThread::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#2  0x00007f3a04a92089 in epicsThreadCallEntryPoint () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39b99b9700) at pthread_create.c:309
Thread 108 (Thread 0x7f39b9118700 (LWP 453922)):
#4  0x00007f3a04f87ff7 in req_server () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a03c72064 in start_thread (arg=0x7f39b9118700) at pthread_create.c:309
Thread 107 (Thread 0x7f39b9017700 (LWP 453923)):
#1  0x00007f3a04f8d296 in cast_server () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39b9017700) at pthread_create.c:309
Thread 106 (Thread 0x7f39b8f16700 (LWP 453924)):
#2  0x00007f3a04f8d6cb in rsrv_online_notify_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39b8f16700) at pthread_create.c:309
Thread 105 (Thread 0x7f39b8e95700 (LWP 453925)):
#1  0x00007f3a05809818 in shWaitFor () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#2  0x00007f3a05809c8e in shRecvExact () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#3  0x00007f3a0580a58d in casterRecvPMsg () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#4  0x00007f3a0580ae5f in doCasterTCPPhase () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#5  0x00007f3a0580a41a in casterThread () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/recsync/client/lib/linux-x86_64/libreccaster.so.0
#6  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#7  0x00007f3a03c72064 in start_thread (arg=0x7f39b8e95700) at pthread_create.c:309
#8  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 104 (Thread 0x7f39b8e14700 (LWP 453928)):
#2  0x00007f3a04a9bc1c in epicsMessageQueueReceiveWithTimeout () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a05a22f9e in save_restore () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/autosave-R5-10/lib/linux-x86_64/libautosave.so
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b8e14700) at pthread_create.c:309
Thread 103 (Thread 0x7f39b8c13700 (LWP 453929)):
#2  0x00007f3a04a8abac in logClientRestart () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#4  0x00007f3a03c72064 in start_thread (arg=0x7f39b8c13700) at pthread_create.c:309
Thread 102 (Thread 0x7f39b8b92700 (LWP 453930)):
#3  0x00007f3a06076ebe in caPutLogTask () from /home/jtagger/EPICS/R3_15_8-x86_64/modules/soft/caPutLog-3.6/lib/linux-x86_64/libcaPutLog.so
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b8b92700) at pthread_create.c:309
Thread 101 (Thread 0x7f39b8ad0700 (LWP 453931)):
#3  0x00007f3a04f6018c in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b8ad0700) at pthread_create.c:309
Thread 100 (Thread 0x7f39b89cf700 (LWP 453932)):
#0  0x00007f3a03f704db in __libc_recv (fd=5, buf=0x7f39b8b09010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#1  0x00007f3a04f881bd in camsgtask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39b89cf700) at pthread_create.c:309
Thread 99 (Thread 0x7f39b87ce700 (LWP 453933)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b87ce700) at pthread_create.c:309
Thread 98 (Thread 0x7f39b86cd700 (LWP 453934)):
#0  0x00007f3a03f704db in __libc_recv (fd=29, buf=0x7f39b8b01010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39b86cd700) at pthread_create.c:309
Thread 97 (Thread 0x7f39b84cc700 (LWP 453935)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39b84cc700) at pthread_create.c:309
Thread 96 (Thread 0x7f39b83cb700 (LWP 453936)):
#0  0x00007f3a03f704db in __libc_recv (fd=30, buf=0x7f39b8af9010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f39b83cb700) at pthread_create.c:309
Thread 95 (Thread 0x7f394b7fa700 (LWP 453962)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394b7fa700) at pthread_create.c:309
Thread 94 (Thread 0x7f394b6f9700 (LWP 453964)):
#0  0x00007f3a03f704db in __libc_recv (fd=34, buf=0x7f39b8ad9010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394b6f9700) at pthread_create.c:309
Thread 93 (Thread 0x7f394955b700 (LWP 454593)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394955b700) at pthread_create.c:309
Thread 92 (Thread 0x7f394945a700 (LWP 454594)):
#0  0x00007f3a03f704db in __libc_recv (fd=45, buf=0x7f39b8078010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394945a700) at pthread_create.c:309
Thread 91 (Thread 0x7f3948c55700 (LWP 454622)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3948c55700) at pthread_create.c:309
Thread 90 (Thread 0x7f394824e700 (LWP 454708)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394824e700) at pthread_create.c:309
Thread 89 (Thread 0x7f38a7fff700 (LWP 454709)):
#0  0x00007f3a03f704db in __libc_recv (fd=51, buf=0x7f39b8048010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a7fff700) at pthread_create.c:309
Thread 88 (Thread 0x7f3948550700 (LWP 67572)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3948550700) at pthread_create.c:309
Thread 87 (Thread 0x7f394844f700 (LWP 67573)):
#0  0x00007f3a03f704db in __libc_recv (fd=58, buf=0x7f39b8054010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394844f700) at pthread_create.c:309
Thread 86 (Thread 0x7f3949259700 (LWP 275248)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3949259700) at pthread_create.c:309
Thread 85 (Thread 0x7f3949158700 (LWP 275249)):
#0  0x00007f3a03f704db in __libc_recv (fd=46, buf=0x7f39b8070010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3949158700) at pthread_create.c:309
Thread 83 (Thread 0x7f39b96b7700 (LWP 66432)):
#3  0x00007f3a04d09426 in tcpSendThread::run() () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libca.so.3.15.8
#6  0x00007f3a03c72064 in start_thread (arg=0x7f39b96b7700) at pthread_create.c:309
Thread 82 (Thread 0x7f394abf2700 (LWP 334972)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394abf2700) at pthread_create.c:309
Thread 81 (Thread 0x7f394aaf1700 (LWP 334973)):
#0  0x00007f3a03f704db in __libc_recv (fd=47, buf=0x7f39b80b5010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394aaf1700) at pthread_create.c:309
Thread 80 (Thread 0x7f394b1f6700 (LWP 239993)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394b1f6700) at pthread_create.c:309
Thread 79 (Thread 0x7f394b0f5700 (LWP 239994)):
#0  0x00007f3a03f704db in __libc_recv (fd=36, buf=0x7f39b80c5010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394b0f5700) at pthread_create.c:309
Thread 78 (Thread 0x7f38a6cf3700 (LWP 16214)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a6cf3700) at pthread_create.c:309
Thread 77 (Thread 0x7f38a6bf2700 (LWP 16215)):
#0  0x00007f3a03f704db in __libc_recv (fd=20, buf=0x7f3948119010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a6bf2700) at pthread_create.c:309
Thread 76 (Thread 0x7f3948f57700 (LWP 401666)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3948f57700) at pthread_create.c:309
Thread 75 (Thread 0x7f3948e56700 (LWP 401667)):
#0  0x00007f3a03f704db in __libc_recv (fd=38, buf=0x7f39b806c010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3948e56700) at pthread_create.c:309
Thread 74 (Thread 0x7f3949ce8700 (LWP 171745)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3949ce8700) at pthread_create.c:309
Thread 73 (Thread 0x7f3949be7700 (LWP 171746)):
#0  0x00007f3a03f704db in __libc_recv (fd=31, buf=0x7f39b8089010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3949be7700) at pthread_create.c:309
Thread 72 (Thread 0x7f38a78fb700 (LWP 314606)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a78fb700) at pthread_create.c:309
Thread 71 (Thread 0x7f38a77fa700 (LWP 314607)):
#0  0x00007f3a03f704db in __libc_recv (fd=33, buf=0x7f3948135010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a77fa700) at pthread_create.c:309
Thread 70 (Thread 0x7f394bdfe700 (LWP 310386)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394bdfe700) at pthread_create.c:309
Thread 69 (Thread 0x7f394bcfd700 (LWP 310387)):
#0  0x00007f3a03f704db in __libc_recv (fd=35, buf=0x7f39b8ae9010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394bcfd700) at pthread_create.c:309
Thread 68 (Thread 0x7f38a75f9700 (LWP 283802)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a75f9700) at pthread_create.c:309
Thread 67 (Thread 0x7f38a74f8700 (LWP 283803)):
#0  0x00007f3a03f704db in __libc_recv (fd=40, buf=0x7f394812d010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a74f8700) at pthread_create.c:309
Thread 66 (Thread 0x7f394810c700 (LWP 380296)):
#0  0x00007f3a03f7064b in __libc_send (fd=41, buf=0x7f3948145010, n=200, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/send.c:31
#1  0x00007f3a04f84d5a in cas_send_bs_msg () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#2  0x00007f3a04f89338 in read_reply () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#3  0x00007f3a04f60317 in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394810c700) at pthread_create.c:309
Thread 65 (Thread 0x7f38a7dfe700 (LWP 380297)):
#0  0x00007f3a03f704db in __libc_recv (fd=41, buf=0x7f3948149010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a7dfe700) at pthread_create.c:309
Thread 64 (Thread 0x7f38a69f1700 (LWP 14863)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a69f1700) at pthread_create.c:309
Thread 63 (Thread 0x7f38a68f0700 (LWP 14864)):
#0  0x00007f3a03f704db in __libc_recv (fd=37, buf=0x7f394810d010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a68f0700) at pthread_create.c:309
Thread 62 (Thread 0x7f39b81ca700 (LWP 82076)):
#6  0x00007f3a04f892c6 in read_reply () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04f60317 in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#9  0x00007f3a03c72064 in start_thread (arg=0x7f39b81ca700) at pthread_create.c:309
Thread 61 (Thread 0x7f394bfff700 (LWP 82077)):
#2  0x00007f3a04a96c7d in epicsAssert () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#3  0x00007f3a04f5fedb in db_queue_event_log () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#4  0x00007f3a04f6012d in db_post_single_event () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f8a1e1 in event_add_action () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04f8b72e in camessage () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04f881e3 in camsgtask () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#9  0x00007f3a03c72064 in start_thread (arg=0x7f394bfff700) at pthread_create.c:309
Thread 60 (Thread 0x7f38a7bfd700 (LWP 266698)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a7bfd700) at pthread_create.c:309
Thread 59 (Thread 0x7f38a7afc700 (LWP 266699)):
#0  0x00007f3a03f704db in __libc_recv (fd=9, buf=0x7f394813d010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f38a7afc700) at pthread_create.c:309
Thread 58 (Thread 0x7f394a8f0700 (LWP 122817)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394a8f0700) at pthread_create.c:309
Thread 57 (Thread 0x7f394a7ef700 (LWP 122818)):
#0  0x00007f3a03f704db in __libc_recv (fd=43, buf=0x7f39b80ad010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394a7ef700) at pthread_create.c:309
Thread 56 (Thread 0x7f394bafc700 (LWP 263620)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394bafc700) at pthread_create.c:309
Thread 55 (Thread 0x7f394b9fb700 (LWP 263621)):
#0  0x00007f3a03f704db in __libc_recv (fd=39, buf=0x7f39b8ae1010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394b9fb700) at pthread_create.c:309
Thread 54 (Thread 0x7f394a5ee700 (LWP 388381)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f394a5ee700) at pthread_create.c:309
Thread 53 (Thread 0x7f394a4ed700 (LWP 388382)):
#0  0x00007f3a03f704db in __libc_recv (fd=52, buf=0x7f39b80a5010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f394a4ed700) at pthread_create.c:309
Thread 52 (Thread 0x7f394aef4700 (LWP 253440)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f397800eef0) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f8c716 in claim_ciu_reply () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f8ce8a in rsrv_extra_labor () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04f601de in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a04a97d0c in start_routine () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#8  0x00007f3a03c72064 in start_thread (arg=0x7f394aef4700) at pthread_create.c:309
#9  0x00007f3a03f6f62d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 51 (Thread 0x7f394adf3700 (LWP 253441)):
Thread 50 (Thread 0x7f38a66ae700 (LWP 103788)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978043e30) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f891a5 in read_reply () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f60317 in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a03c72064 in start_thread (arg=0x7f38a66ae700) at pthread_create.c:309
Thread 49 (Thread 0x7f38a65ad700 (LWP 103789)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f38a65ad700) at pthread_create.c:309
Thread 48 (Thread 0x7f3948852700 (LWP 235726)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978038690) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f8cf11 in rsrv_extra_labor () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f601de in event_task () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#7  0x00007f3a03c72064 in start_thread (arg=0x7f3948852700) at pthread_create.c:309
Thread 47 (Thread 0x7f3948751700 (LWP 235727)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f3948751700) at pthread_create.c:309
Thread 46 (Thread 0x7f38a72f7700 (LWP 312192)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f397801ab10) at ../nptl/pthread_mutex_lock.c:114
#7  0x00007f3a03c72064 in start_thread (arg=0x7f38a72f7700) at pthread_create.c:309
Thread 45 (Thread 0x7f38a71f6700 (LWP 312193)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f38a71f6700) at pthread_create.c:309
Thread 44 (Thread 0x7f3a028b0700 (LWP 314016)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a028b0700) at pthread_create.c:309
Thread 43 (Thread 0x7f3a027af700 (LWP 314017)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f3a027af700) at pthread_create.c:309
Thread 42 (Thread 0x7f3949fea700 (LWP 314553)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3949fea700) at pthread_create.c:309
Thread 41 (Thread 0x7f3949ee9700 (LWP 314554)):
#0  0x00007f3a03f704db in __libc_recv (fd=60, buf=0x7f39b8091010, n=16384, flags=-1) at ../sysdeps/unix/sysv/linux/x86_64/recv.c:33
#3  0x00007f3a03c72064 in start_thread (arg=0x7f3949ee9700) at pthread_create.c:309
Thread 40 (Thread 0x7f3a02bb2700 (LWP 318443)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a02bb2700) at pthread_create.c:309
Thread 39 (Thread 0x7f3a02ab1700 (LWP 318444)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f3a02ab1700) at pthread_create.c:309
Thread 38 (Thread 0x7f394b4f8700 (LWP 319105)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978045930) at ../nptl/pthread_mutex_lock.c:114
#7  0x00007f3a03c72064 in start_thread (arg=0x7f394b4f8700) at pthread_create.c:309
Thread 37 (Thread 0x7f394b3f7700 (LWP 319106)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f394b3f7700) at pthread_create.c:309
Thread 36 (Thread 0x7f394a2ec700 (LWP 319383)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f3978045eb0) at ../nptl/pthread_mutex_lock.c:114
#7  0x00007f3a03c72064 in start_thread (arg=0x7f394a2ec700) at pthread_create.c:309
Thread 35 (Thread 0x7f394a1eb700 (LWP 319384)):
#10 0x00007f3a03c72064 in start_thread (arg=0x7f394a1eb700) at pthread_create.c:309
Thread 34 (Thread 0x7f3a025ae700 (LWP 389012)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3a025ae700) at pthread_create.c:309
Thread 33 (Thread 0x7f39499e6700 (LWP 389013)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x1808150) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04a77386 in asAddClient () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#5  0x00007f3a04f8c95c in claim_ciu_action () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#9  0x00007f3a03c72064 in start_thread (arg=0x7f39499e6700) at pthread_create.c:309
Thread 32 (Thread 0x7f39497e5700 (LWP 390381)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f39497e5700) at pthread_create.c:309
Thread 31 (Thread 0x7f3948b54700 (LWP 390382)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f3948b54700) at pthread_create.c:309
Thread 30 (Thread 0x7f3948953700 (LWP 391765)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f3948953700) at pthread_create.c:309
Thread 29 (Thread 0x7f38a6ff5700 (LWP 391766)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a6ff5700) at pthread_create.c:309
Thread 28 (Thread 0x7f38a6df4700 (LWP 392248)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a6df4700) at pthread_create.c:309
Thread 27 (Thread 0x7f38a63ac700 (LWP 392249)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a63ac700) at pthread_create.c:309
Thread 26 (Thread 0x7f38a61ab700 (LWP 393036)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a61ab700) at pthread_create.c:309
Thread 25 (Thread 0x7f38a60aa700 (LWP 393037)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a60aa700) at pthread_create.c:309
Thread 24 (Thread 0x7f38a5ea9700 (LWP 394387)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a5ea9700) at pthread_create.c:309
Thread 23 (Thread 0x7f38a5da8700 (LWP 394388)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a5da8700) at pthread_create.c:309
Thread 22 (Thread 0x7f38a5ba7700 (LWP 395812)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a5ba7700) at pthread_create.c:309
Thread 21 (Thread 0x7f38a5aa6700 (LWP 395813)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a5aa6700) at pthread_create.c:309
Thread 20 (Thread 0x7f38a58a5700 (LWP 397184)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a58a5700) at pthread_create.c:309
Thread 19 (Thread 0x7f38a57a4700 (LWP 397185)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a57a4700) at pthread_create.c:309
Thread 18 (Thread 0x7f38a55a3700 (LWP 398551)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a55a3700) at pthread_create.c:309
Thread 17 (Thread 0x7f38a54a2700 (LWP 398552)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a54a2700) at pthread_create.c:309
Thread 16 (Thread 0x7f38a52a1700 (LWP 399894)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a52a1700) at pthread_create.c:309
Thread 15 (Thread 0x7f38a51a0700 (LWP 399895)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a51a0700) at pthread_create.c:309
Thread 14 (Thread 0x7f38a4f9f700 (LWP 399973)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a4f9f700) at pthread_create.c:309
Thread 13 (Thread 0x7f38a4e9e700 (LWP 399974)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a4e9e700) at pthread_create.c:309
Thread 12 (Thread 0x7f38a4c9d700 (LWP 400630)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a4c9d700) at pthread_create.c:309
Thread 11 (Thread 0x7f38a4b9c700 (LWP 400631)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a4b9c700) at pthread_create.c:309
Thread 10 (Thread 0x7f38a499b700 (LWP 401320)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a499b700) at pthread_create.c:309
Thread 9 (Thread 0x7f38a489a700 (LWP 401321)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a489a700) at pthread_create.c:309
Thread 8 (Thread 0x7f38a4699700 (LWP 402224)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a4699700) at pthread_create.c:309
Thread 7 (Thread 0x7f38a4598700 (LWP 402225)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a4598700) at pthread_create.c:309
Thread 6 (Thread 0x7f38a4397700 (LWP 402692)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f38a4397700) at pthread_create.c:309
Thread 5 (Thread 0x7f38a4296700 (LWP 402693)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f38a4296700) at pthread_create.c:309
Thread 4 (Thread 0x7f382bfff700 (LWP 404260)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f382bfff700) at pthread_create.c:309
Thread 3 (Thread 0x7f382befe700 (LWP 404261)):
#9  0x00007f3a03c72064 in start_thread (arg=0x7f382befe700) at pthread_create.c:309
Thread 2 (Thread 0x7f382bcfd700 (LWP 405627)):
#5  0x00007f3a03c72064 in start_thread (arg=0x7f382bcfd700) at pthread_create.c:309
Thread 1 (Thread 0x7f3a06b72740 (LWP 453868)):
#2  0x00007f3a03c742f6 in __GI___pthread_mutex_lock (mutex=0x7f397800efd0) at ../nptl/pthread_mutex_lock.c:114
#4  0x00007f3a04f85a2b in log_one_client () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#5  0x00007f3a04f85e73 in casr () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libdbCore.so.3.15.8
#6  0x00007f3a04a88829 in iocshBody () from /home/jtagger/EPICS/R3_15_8-x86_64/base-3.15.8/lib/linux-x86_64/libCom.so.3.15.8
#7  0x0000000000406626 in main ()
jtagger@linde-sm1:/epics/iocs/SR-Cry$
Re: EPICS stopped Michael Davidsaver via Tech-talk
EPICS stopped Tagger, Jueri via Tech-talk
RE: EPICS stopped Mark Rivers via Tech-talk
RE: EPICS stopped Tagger, Jueri via Tech-talk
Prev: Re: EPICS stopped Sinclair, John via Tech-talk
Next: Re: EPICS stopped Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
