1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Modbus & asynManager::queueLockPort queueRequest failed: port not connected
From: Keara Louise Soloway via Tech-talk <[email protected]>
Date: Thu, 20 May 2021 20:40:32 +0000
Greetings all,
I am having problems communicating with an Automation Direct BRX PLC. The problems are not consistently reproducible -- IOC starts without any error at all about 1 in 5 times. The errors only happen when starting the IOC, never when it's already running normally.
The IOC application uses:
EPICS base 7.0.2
alive R1-1-1
asyn R4-40
calc R3-7-3
modbus R3-0
sscan R2-11-3
Here are the errors and some context from the ioc shell:
dbLoadDatabase("../../dbd/heatedprintbed.dbd")
heatedprintbed_registerRecordDeviceDriver(pdbbase)
< errordemo.cmd
drvAsynIPPortConfigure("IP_PORT", "192.168.182.136:502",0,0,1)
modbusInterposeConfig("IP_PORT",0,5000,0)
drvModbusAsynConfigure("MI_READ", "IP_PORT", 255, 2, 549, 11, 0, 250, "BRX")
drvModbusAsynConfigure("MC_READ",  "IP_PORT", 255, 1, 1999, 5, 0, 250, "BRX")
drvModbusAsynConfigure("MC_WRITE", "IP_PORT", 255, 5, 1999, 5, 0, 250, "BRX")
2021/05/20 15:58:50.578 drvModbusAsyn::doModbusIO port MC_WRITE error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port IP_PORT not connected, nwrite=0/6, nread=0
## Load record instances
dbLoadTemplate("../../db/errordemo.substitutions")
iocInit
Starting iocInit
## EPICS R7.0.2
## EPICS Base built Apr  5 2019
2021/05/20 15:58:50.828 drvModbusAsyn::doModbusIO port MI_READ error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port IP_PORT not connected, nwrite=0/6, nread=0
2021/05/20 15:58:50.828 drvModbusAsyn::doModbusIO port MC_READ error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port IP_PORT not connected, nwrite=0/6, nread=0
## Start any sequence programs
#seq sncxxx,"user=kls286"
epics> 2021/05/20 16:01:25.169 drvModbusAsyn::doModbusIO port MI_READ writeRead status back to normal having had 124 errors, nwrite=6/6, nread=4
2021/05/20 16:01:25.175 drvModbusAsyn::doModbusIO port MC_READ writeRead status back to normal having had 124 errors, nwrite=6/6, nread=3
After a few minutes (variable, but usually less than 10), all of the read-only modbus ports put out a "back to normal" message like the one above. The claim of "back to normal" does indeed seem to be true -- all PVs reading from these ports do so as intended.
The write-only modbus ports also go back to normal as soon as I do a dbpf to any of the PVs that will write to the port. Like so:
epics> dbpf demoButton:write 1
DBF_STRING:         "Pushed"
epics> 2021/05/20 16:04:37.323 drvModbusAsyn::doModbusIO port MC_WRITE writeRead status back to normal having had 1 errors, nwrite=6/6, nread=5
Let me know if I can provide any additional details.
K. Soloway
Re: Modbus & asynManager::queueLockPort queueRequest failed: port not connected Mark Rivers via Tech-talk
Prev: Re: EPICS stopped Michael Davidsaver via Tech-talk
Next: RE: Archiver Appliance mgmt tomcat issue Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] asyn vxi11 rpc issue cross compile for yocto powerpc64-fsl-linux Heinz Junkes via Tech-talk
Next: Re: Modbus & asynManager::queueLockPort queueRequest failed: port not connected Mark Rivers via Tech-talk
