1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: caRepeater w/ systemd?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Sun, 23 May 2021 07:57:07 -0700
The caRepeater.service currently included in Base is in need of improvement.
eg. to not run as root.
https://github.com/epics-base/epics-base/blob/b777233efb06fa4e988c4f0738b0270dd3d095a3/modules/ca/src/client/caRepeater.service%40#L1
Has anyone gone through the exercise of producing a unit file which restricts caRepeater?
Maybe with PrivateUsers=true to avoid manually allocating a username,
and/or some restrictions on filesystem access?
Ideally a unit file in Base would work back to systemd 219 (circa rhel/centos7)
without modification.  Although this doesn't seem like a hard requirement to me.
It seems reasonable to have some comments describing any edits needed with older systemd.
Re: caRepeater w/ systemd? Johnson, Andrew N. via Tech-talk
Prev: Re: SNMP in EPICS Tomasz Brys via Tech-talk
Next: using autosave, iocInit hangs junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: SNMP in EPICS Dunning, Michael via Tech-talk
Next: Re: caRepeater w/ systemd? Johnson, Andrew N. via Tech-talk
