I was using EPICS 7 with RTEMS 5 and have now also enabled autosave.
Unfortunately in Main iocInit does not come back but hangs at the last
InitHookAnnounce in iocRun
if (iocState == iocBuilt)
initHookAnnounce(initHookAtEnd);
errlogPrintf("iocRun: %s\n", iocState == iocBuilt ?
"All initialization complete" :
"IOC restarted");
iocState = iocRunning;
initHookAnnounce(initHookAfterIocRunning);
return 0;
and no new iocsh(NULL) is started.
int main(int argc,char *argv[])
if(argc>=2) {
iocsh(argv[1]); <----- here it gets stuck
epicsThreadSleep(.2);
iocsh(NULL);
# autosave setup
dbLoadRecords("db/save_restoreStatus.db", "P=iocvmeIOC3:")
## autoSaveRestore setup
save_restoreSet_Debug(0)
# status-PV prefix, so save_restore can find its status PV's.
save_restoreSet_status_prefix("iocvmeIOC3:")
# ok to restore a save set that had missing values (no CA connection to
PV)?
# ok to save a file if some CA connections are bad?
save_restoreSet_IncompleteSetsOk(1)
#In the restore operation, a copy of the save file will be written. The
# file name can look like "auto_settings.sav.bu", and be overwritten
every
# reboot, or it can look like "auto_settings.sav_020306-083522" (this is
what
# is meant by a dated backup file) and every reboot will write a new
copy.
save_restoreSet_DatedBackupFiles(1)
# specify where save files should go
set_savefile_path("/Volumes/Epics/LogDir/log/as","/save")
# specify where request files can be found
set_requestfile_path("/Volumes/Epics/LogDir/log/as","/req")
# Specify what save files should be restored when.
# Up to eight files can be specified for each pass.
set_pass0_restoreFile("iocvmeIOC3_0.sav")
set_pass1_restoreFile("iocvmeIOC3_1.sav")
# Number of sequenced backup files (e.g., 'auto_settings.sav0') to write
save_restoreSet_NumSeqFiles(3)
save_restoreSet_SeqPeriodInSeconds(600)
# Time between failed .sav-file write and the retry.
save_restoreSet_RetrySeconds(60)
makeAutosaveFileFromDbInfo("/Volumes/Epics/LogDir/log/as/req/iocvmeIOC3_0.req",
"autosaveFields_pass0")
makeAutosaveFileFromDbInfo("/Volumes/Epics/LogDir/log/as/req/iocvmeIOC3_1.req",
"autosaveFields_pass1")
iocInit
iocInit: Reached initHookAtIocBuild
Starting iocInit
iocInit: Reached initHookAtBeginning
## EPICS R7.0.4.2-DEV
## Rev. R7.0.4.1-274-g31ade32004709a9d47e8-dirty
iocInit: Reached initHookAfterCallbackInit
iocInit: Reached initHookAfterCaLinkInit
iocInit: Reached initHookAfterInitDrvSup
iocInit: Reached initHookAfterInitRecSup
reboot_restore: entry for file 'iocvmeIOC3_0.sav'
reboot_restore: Found filename 'iocvmeIOC3_0.sav' in restoreFileList.
*** restoring from '/Volumes/Epics/LogDir/log/as/save/iocvmeIOC3_0.sav'
at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'iocvmeIOC3_0.sav'
iocInit: Reached initHookAfterInitDevSup
2021/05/23 20:07:03.501 sis0: Param Timestamp Clear can not be read
reboot_restore: entry for file 'iocvmeIOC3_1.sav'
reboot_restore: Found filename 'iocvmeIOC3_1.sav' in restoreFileList.
*** restoring from '/Volumes/Epics/LogDir/log/as/save/iocvmeIOC3_1.sav'
at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'iocvmeIOC3_1.sav'
iocInit: Reached initHookAfterInitDatabase
iocInit: Reached initHookAfterFinishDevSup
iocInit: Reached initHookAfterScanInit
iocInit: Reached initHookAfterInitialProcess
iocInit: Reached initHookAfterCaServerInit
iocInit: Reached initHookAfterIocBuilt
iocInit: Reached initHookAtIocRun
iocInit: Reached initHookAfterDatabaseRunning
iocInit: Reached Not an initHookState
iocInit: Reached initHookAfterCaServerRunning
no return ...
Danke, Heinz
- Re: using autosave, iocInit hangs Heinz Junkes via Tech-talk
caRepeater w/ systemd? Michael Davidsaver via Tech-talk
Re: caRepeater w/ systemd? Johnson, Andrew N. via Tech-talk
<2021>
Re: caRepeater w/ systemd? Ernesto Paiser via Tech-talk
<2021>
