1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: caRepeater w/ systemd?
From: Ernesto Paiser via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 4 Jun 2021 17:14:31 -0700
Hi Michael,
I've installed caRepeater as a systemd service at boot time
as private user not root on RHEL8 (see below):
ImYourMasterAndYouMySlave #> cat caRepeater.service
# Linux systemd service file for the EPICS CA Repeater
# To install this file, as root:
#   cp caRepeater.service /etc/systemd/system
#   chmod 664 /etc/systemd/system/caRepeater.service
#   systemctl daemon-reload
#   systemctl enable caRepeater
#   systemctl start caRepeater
# To check the status:
#   systemctl status caRepeater
[Unit]
Description=EPICS CA Repeater
Requires=multi-user.target
After=multi-user.target
[Service]
ExecStart=/opt/epics/R3.15.5/base/bin/linux-x86_64/caRepeater
Restart=on-failure
User=epics2
[Install]
WantedBy=multi-user.target
On 5/30/21 7:15 AM, Michael Davidsaver via Tech-talk wrote:
CAUTION: *** EMAIL ORIGINATED FROM OUTSIDE THE ORGANIZATION. Please do not click links or open attachments unless you know the contents are safe. Verify that you recognize sender email address before clicking any link or attachment. DO NOT enter/change any password when clicking on a link. ***
On 5/24/21 9:33 AM, Johnson, Andrew N. wrote:
On May 23, 2021, at 9:57 AM, Michael Davidsaver via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
The caRepeater.service currently included in Base is in need of improvement.
eg. to not run as root.
That’s about the one thing that it /doesn’t/ do, line 22 <https://github.com/epics-base/epics-base/blob/b777233efb06fa4e988c4f0738b0270dd3d095a3/modules/ca/src/client/caRepeater.service@#L22> configures it to run as daemon:
Daemons can (and imo should) be constrained to prevent unnecessary operations.
eg. disallow filesystem writes with "ProtectSystem=strict" when run as root.
Or "ProtectHome=true" "PrivateTmp=true" to prevent snooping.
This is an expression of the idea of defense in depth, and is generally seen
as good practice these days.  Especially for a network service.
*tux% *ps -ef | grep caRepeater
daemon    2255     1  0 Apr21 ?        00:02:51 /usr/bin/*caRepeater*
*tux% *systemctl status caRepeater.service
*●*caRepeater.service - EPICS CA Repeater
    Loaded: loaded (/usr/lib/systemd/system/caRepeater.service; enabled; vendor preset: disabled)
    Active: *active (running)*since Wed 2021-04-21 09:03:16 CDT; 1 months 2 days ago
  Main PID: 2255 (caRepeater)
     Tasks: 1
    CGroup: /system.slice/caRepeater.service
            └─2255 /usr/bin/caRepeater
I’m not saying it couldn’t be significantly improved <https://www.redhat.com/sysadmin/systemd-secure-services> though:
*$ *systemd-analyze security caRepeater.service
   NAME                                                        DESCRIPTION                                                             EXPOSURE
*✗*PrivateNetwork=                                             Service has access to the host's network                                     0.5
*✓*User=/DynamicUser=                                          Service runs under a static non-root user identity
*✗*CapabilityBoundingSet=~CAP_SET(UID|GID|PCAP)                Service may change UID/GID identities/capabilities                           0.3
*✗*CapabilityBoundingSet=~CAP_SYS_ADMIN                        Service has administrator privileges                                         0.3
*✗*CapabilityBoundingSet=~CAP_SYS_PTRACE                       Service has ptrace() debugging abilities                                     0.3
*✗*RestrictAddressFamilies=~AF_(INET|INET6)                    Service may allocate Internet sockets                                        0.3
*✗*RestrictNamespaces=~CLONE_NEWUSER                           Service may create user namespaces                                           0.3
*✗*RestrictAddressFamilies=~…                                  Service may allocate exotic sockets                                          0.3
*✗*CapabilityBoundingSet=~CAP_(CHOWN|FSETID|SETFCAP)           Service may change file ownership/access mode/capabilities unrestricted      0.2
*✗*CapabilityBoundingSet=~CAP_(DAC_*|FOWNER|IPC_OWNER)         Service may override UNIX file/IPC permission checks                         0.2
*✗*CapabilityBoundingSet=~CAP_NET_ADMIN                        Service has network configuration privileges                                 0.2
*✗*CapabilityBoundingSet=~CAP_RAWIO                            Service has raw I/O access                                                   0.2
*✗*CapabilityBoundingSet=~CAP_SYS_MODULE                       Service may load kernel modules                                              0.2
*✗*CapabilityBoundingSet=~CAP_SYS_TIME                         Service processes may change the system clock                                0.2
*✗*DeviceAllow=                                                Service has no device ACL                                                    0.2
*✗*IPAddressDeny=                                              Service does not define an IP address whitelist                              0.2
*✓*KeyringMode=                                                Service doesn't share key material with other services
*✗*NoNewPrivileges=                                            Service processes may acquire new privileges                                 0.2
*✓*NotifyAccess=                                               Service child processes cannot alter service state
*✗*PrivateDevices=                                             Service potentially has access to hardware devices                           0.2
*✗*PrivateMounts=                                              Service may install system mounts                                            0.2
*✗*PrivateTmp=                                                 Service has access to other software's temporary files                       0.2
*✗*PrivateUsers=                                               Service has access to other users                                            0.2
*✗*ProtectControlGroups=                                       Service may modify to the control group file system                          0.2
*✗*ProtectHome=                                                Service has full access to home directories                                  0.2
*✗*ProtectKernelModules=                                       Service may load or read kernel modules                                      0.2
*✗*ProtectKernelTunables=                                      Service may alter kernel tunables                                            0.2
*✗*ProtectSystem=                                              Service has full access the OS file hierarchy                                0.2
*✗*RestrictAddressFamilies=~AF_PACKET                          Service may allocate packet sockets                                          0.2
*✗*RestrictSUIDSGID=                                           Service may create SUID/SGID files                                           0.2
*✗*SystemCallArchitectures=                                    Service may execute system calls with all ABIs                               0.2
*✗*SystemCallFilter=~@clock                                    Service does not filter system calls                                         0.2
*✗*SystemCallFilter=~@debug                                    Service does not filter system calls                                         0.2
*✗*SystemCallFilter=~@module                                   Service does not filter system calls                                         0.2
*✗*SystemCallFilter=~@mount                                    Service does not filter system calls                                         0.2
*✗*SystemCallFilter=~@raw-io                                   Service does not filter system calls                                         0.2
*✗*SystemCallFilter=~@reboot                                   Service does not filter system calls                                         0.2
*✗*SystemCallFilter=~@swap                                     Service does not filter system calls                                         0.2
*✗*SystemCallFilter=~@privileged                               Service does not filter system calls                                         0.2
*✗*SystemCallFilter=~@resources                                Service does not filter system calls                                         0.2
*✓*AmbientCapabilities=                                        Service process does not receive ambient capabilities
*✗*CapabilityBoundingSet=~CAP_AUDIT_*                          Service has audit subsystem access                                           0.1
*✗*CapabilityBoundingSet=~CAP_KILL                             Service may send UNIX signals to arbitrary processes                         0.1
*✗*CapabilityBoundingSet=~CAP_MKNOD                            Service may create device nodes                                              0.1
*✗*CapabilityBoundingSet=~CAP_NET_(BIND_SERVICE|BROADCAST|RAW) Service has elevated networking privileges                                   0.1
*✗*CapabilityBoundingSet=~CAP_SYSLOG                           Service has access to kernel logging                                         0.1
*✗*CapabilityBoundingSet=~CAP_SYS_(NICE|RESOURCE)              Service has privileges to change resource use parameters                     0.1
*✗*RestrictNamespaces=~CLONE_NEWCGROUP                         Service may create cgroup namespaces                                         0.1
*✗*RestrictNamespaces=~CLONE_NEWIPC                            Service may create IPC namespaces                                            0.1
*✗*RestrictNamespaces=~CLONE_NEWNET                            Service may create network namespaces                                        0.1
*✗*RestrictNamespaces=~CLONE_NEWNS                             Service may create file system namespaces                                    0.1
*✗*RestrictNamespaces=~CLONE_NEWPID                            Service may create process namespaces                                        0.1
*✗*RestrictRealtime=                                           Service may acquire realtime scheduling                                      0.1
*✗*SystemCallFilter=~@cpu-emulation                            Service does not filter system calls                                         0.1
*✗*SystemCallFilter=~@obsolete                                 Service does not filter system calls                                         0.1
*✗*RestrictAddressFamilies=~AF_NETLINK                         Service may allocate netlink sockets                                         0.1
*✗*RootDirectory=/RootImage=                                   Service runs within the host's root directory                                0.1
*✓*SupplementaryGroups=                                        Service has no supplementary groups
*✗*CapabilityBoundingSet=~CAP_MAC_*                            Service may adjust SMACK MAC                                                 0.1
*✗*CapabilityBoundingSet=~CAP_SYS_BOOT                         Service may issue reboot()                                                   0.1
*✓*Delegate=                                                   Service does not maintain its own delegated control group subtree
*✗*LockPersonality=                                            Service may change ABI personality                                           0.1
*✗*MemoryDenyWriteExecute=                                     Service may create writable executable memory mappings                       0.1
*✗*RemoveIPC=                                                  Service user may leave SysV IPC objects around                               0.1
*✗*RestrictNamespaces=~CLONE_NEWUTS                            Service may create hostname namespaces                                       0.1
*✗*UMask=                                                      Files created by service are world-readable by default                       0.1
*✗*CapabilityBoundingSet=~CAP_LINUX_IMMUTABLE                  Service may mark files immutable                                             0.1
*✗*CapabilityBoundingSet=~CAP_IPC_LOCK                         Service may lock memory into RAM                                             0.1
*✗*CapabilityBoundingSet=~CAP_SYS_CHROOT                       Service may issue chroot()                                                   0.1
*✗*CapabilityBoundingSet=~CAP_BLOCK_SUSPEND                    Service may establish wake locks                                             0.1
*✗*CapabilityBoundingSet=~CAP_LEASE                            Service may create file leases                                               0.1
*✗*CapabilityBoundingSet=~CAP_SYS_PACCT                        Service may use acct()                                                       0.1
*✗*CapabilityBoundingSet=~CAP_SYS_TTY_CONFIG                   Service may issue vhangup()                                                  0.1
*✗*CapabilityBoundingSet=~CAP_WAKE_ALARM                       Service may program timers that wake up the system                           0.1
*✗*RestrictAddressFamilies=~AF_UNIX                            Service may allocate local sockets                                           0.1
→ *Overall exposure level for caRepeater.service*: *9.1 UNSAFE*😨
- Andrew
Complexity comes for free, simplicity you have to work for.
caRepeater w/ systemd? Michael Davidsaver via Tech-talk
Re: caRepeater w/ systemd? Johnson, Andrew N. via Tech-talk
Re: caRepeater w/ systemd? Michael Davidsaver via Tech-talk
Prev: Re: Modbus & asynManager::queueLockPort queueRequest failed: port not connected Mark Rivers via Tech-talk
Next: Re: using autosave, iocInit hangs Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: caRepeater w/ systemd? Michael Davidsaver via Tech-talk
Next: using autosave, iocInit hangs junkes via Tech-talk
