1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Issue with FPGA based encoder box when running with EPICS 7.0.5
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
Cc: "Hanwell, Marcus" <[email protected]>
Date: Tue, 25 May 2021 01:14:46 +0000
Hi all,
we have recently observed a bizarre bug with one of our pizzabox encoders at NSLS2 that cropped up during the migration of its IOC to RHEL 8. As part of the migration, we modernized the EPICS modules that it depended on, including EPICS base. The IOC uses the pscdrv module as a base, with two additional *App directories. When first moving to RHEL 8, I had to make some minor changes, which can be found in the following two commit diffs:
These changes allowed the IOC to build on RHEL 8 without any problems. However, when running the IOC and collecting some data from the encoder, we encountered a strange issue. Essentially, from the box, we collect a count of nanoseconds and seconds. The nanoseconds count up to one second and then reset to 0, while the seconds counter gets a reading after every second. This data is then combined to give a straight line representing time to nanosecond accuracy. Unfortunately, what ended up happening was that the first batch of data written to the datafile was corrupted, which then caused the nanosecond and second counters to become out of sync - causing the graph to become jagged. (See the linked images for a visualization. Note in the one with the three way split, how the initial data is corrupted vs the normal data):
We did not see any error or warning messages in the IOC shell, and after some trial and error we tried with an older version of base + modules, 3.14.*, and modules circa 2017. This resolved the problem. Curiously, the initial corrupted data was always 1024 elements, which was both the value of NELM in the waveform records corresponding to the PVs for this data, as well as the hard-coded size of the buffer that is written to memory (using an fprintf call in an aSubRecord callback). Aside from that initial invalid data, the remaining data seems to be consistent and valid, though cannot be used due to being out of sync.
Does anyone have an idea what could possibly cause this kind of behavior? I can send more data/source code snippets if that helps as well. It would be good to figure out a fix to make this IOC work with the version of EPICS base we have now standardized on.
Thanks!
Jakub Wlodek
Re: Issue with FPGA based encoder box when running with EPICS 7.0.5 Joel Sherrill via Tech-talk
Re: Issue with FPGA based encoder box when running with EPICS 7.0.5 Heinz Junkes via Tech-talk
Re: Issue with FPGA based encoder box when running with EPICS 7.0.5 Michael Davidsaver via Tech-talk
Prev: Re: How to set bo PV to zero when starting Modbus IOC Mark Rivers via Tech-talk
Next: Re: Issue with FPGA based encoder box when running with EPICS 7.0.5 Joel Sherrill via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Re: Re: How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
