1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Re: Re: How to set bo PV to zero when starting Modbus IOC
To: "mark rivers" <[email protected]>
Date: Wed, 26 May 2021 08:31:21 +0800 (GMT+08:00)
Hi Mark,
I see,thank you very much.
Best regards.
Gao Zhenhua
> -----原始邮件-----
> 发件人: "Mark Rivers" <[email protected]>
> 发送时间: 2021-05-25 20:12:19 (星期二)
> 收件人: "高振华" <[email protected]>
> 抄送: "[email protected]" <[email protected]>
> 主题: Re: Re: How to set bo PV to zero when starting Modbus IOC
>  Hi Zhenhua,
> > 1. Is the Dbpf command placed after iocInit written to the PLC after the IOC is started and before the scanner mechanism starts scanning processing?
> No, dbpf  happens after iocInit is complete and scanning has started.
> However, if you use autosave and PINI=YES then it does happen as part of iocInit, before scanning starts.
> >  2. Is it performed as the first write to the PLC with the start of the IOC?
> The dbpf will be the first write to that PLC register if you set PINI=NO on the record that writes to that register.  If other records have PINI=YES then it will not be the first write to the PLC, just the first write to that register.
> Mark
> ________________________________
> From: 高振华 <[email protected]>
> Sent: Tuesday, May 25, 2021 2:26 AM
> To: Mark Rivers
> Cc: [email protected]
> Subject: Re: Re: How to set bo PV to zero when starting Modbus IOC
> Hi Mark,
> Thanks,two questions remain:
> Best regards.
> Gao Zhenhua
> > -----原始邮件-----
> > 发送时间: 2021-05-25 09:00:06 (星期二)
> > 主题: Re: How to set bo PV to zero when starting Modbus IOC
> > Hi Zhenhua,
> > The value in the database file will be replaced by the value read from the device.
> > There are 2 ways to force the value to zero when the IOC start up:
> > - Add the PV to autosave and set the value to 0 before the IOC reboots. The value in autosave will be written to the device if PINI=1.
> > - Put a dbpf command after iocInit which writes zero to the PV.
> > Mark
> > Sent from my iPhone
> > > On May 24, 2021, at 7:39 PM, 高振华 <[email protected]> wrote:
> > > Hi Mark,
> > > I tried to set BO PV to zero when starting Modbus R2-11 IOC, but failed. PINI worked, but VAL didn't work.When IOC is started, what is written to PLC is the value that has just been read.
> > > Can't the Modbus R2-11 driver set BO PV to zero when IOC starts?
> > > Best regards.
> > > Gao Zhenhua
> > > BSRF(Beijing Synchrotron Radiation Facility)
> > > Email:[email protected]
> 祝好!
> 高振华
> 电话:010-88235426
祝好!
高振华
电话:010-88235426
How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
Re: How to set bo PV to zero when starting Modbus IOC Mark Rivers via Tech-talk
Re: Re: How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
Re: Re: How to set bo PV to zero when starting Modbus IOC Mark Rivers via Tech-talk
Prev: Re: using autosave, iocInit hangs Heinz Junkes via Tech-talk
Next: Re: SNMP in EPICS Miroslaw Dach via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Re: How to set bo PV to zero when starting Modbus IOC Mark Rivers via Tech-talk
Next: Issue with FPGA based encoder box when running with EPICS 7.0.5 Wlodek, Jakub via Tech-talk
