1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: SNMP in EPICS
From: Miroslaw Dach via Tech-talk <[email protected]>
To: Tomasz Brys <[email protected]>
Date: Tue, 25 May 2021 18:51:05 -0700
Hi Tomasz,
There is a newer version 1.1.0.2 .
Cheers
Mirek
On Fri, May 21, 2021 at 1:30 PM Tomasz Brys via Tech-talk <[email protected]> wrote:
Thank you guys, for all your help.
I am trying to integrate and monitor the Lantime M300/GPS device.
I confirm it works as expect.
One of my records in the db is now:
record(longin, "$(P)$(R)NtpCurrentState") {
  field(DESC, "Status of NTP")
  field(DTYP, "Snmp")
  field(SCAN, "5 second")
  field(INP,  "@$(HOST) $(COMMUNITY) $(MIB)::mbgLtNgNtpCurrentState.0 ( 100 i")
I had to add .0 or .1 in my INP field.
I also added MIBDIRS macro as suggested Michael and remove -c flag as suggested John.
Thank you for pointing me a new version 1.1.0.1
Cheers
Tomasz Brys
European Spallation Source ERIC
From: Tech-talk <[email protected]> on behalf of Pierrick M Hanlet via Tech-talk <[email protected]>
Reply-To: Pierrick M Hanlet <[email protected]>
Date: Friday, 21 May 2021 w:20 at 16:30
Hi Tomasz,
One way in which snmpwalk and snmpget differ is that snmpwalk doesn't specify a specific channel.
However, if you'll notice, it returns MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState.1; note the ".1".  You might
try snmpget with and without it; if my suspicion is correct, then you'll need to add it to your address in the
INP field.
Cheers,
Pierrick
On 5/21/21 3:13 AM, Tomasz Brys via Tech-talk wrote:
I have a problem how to implement SNMP protocol in EPICS.
I want to keep MIB file somewhere in the module, not in the /usr/share/snmp directory.
If I run snmpwalk I can:
snmpwalk -v2c -M +/vagrant/modules/e3-M300_GPS/M300_GPS/M300_GPSApp/MBG-SNMP-MIB -m All -c comm 192.168.XXX.XXX MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState
and I get output:
MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState.1 = INTEGER: synchronized(1)
How should I define my record in Db?
I did it like that:
record(longin, "$(P)$(R)RefclockState"){
  field(DESC, "Status of GPS refclock")
  field(DTYP, "Snmp")
  field(INP,  "@$(HOST) $(COMMUNITY) $(MIB)::mbgLtNgRefclockState Integer: 10")
Where:
$(HOST) = 192.168.XXX.XXX – this is of course fake address
$(COMMUNITY) = -c comm
$(MIB) = MBG-SNMP-LTNG-MIB
But I got error:
devSnmp: error parsing '192.168.XXX.XXX -c comm MBG-SNMP-LTNG-MIB::mbgLtNgRefclockState Integer: 10'
         format is 'host community oidname mask maxdatalength [set_format/special]'
Error (511,511) PV: P:R:RefclockState devSnmpLi (init_record) bad parameters
Any help how I can do this?
Best regards
Tomasz Brys
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
SNMP in EPICS Tomasz Brys via Tech-talk
Re: SNMP in EPICS Pierrick M Hanlet via Tech-talk
Re: SNMP in EPICS Tomasz Brys via Tech-talk
Prev: Re: Re: Re: How to set bo PV to zero when starting Modbus IOC 高振华 via Tech-talk
Next: offset correction in PerkinElmer AreaDetector [SEC=OFFICIAL] CORNALL, Terry via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: SNMP in EPICS Tomasz Brys via Tech-talk
Next: Re: SNMP in EPICS Dunning, Michael via Tech-talk
