1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: offset correction in PerkinElmer AreaDetector [SEC=OFFICIAL]
From: "CORNALL, Terry via Tech-talk" <[email protected]>
Cc: "BRAND, Helen" <[email protected]>
Date: Wed, 26 May 2021 04:08:38 +0000
Hi All.
We have a Varex XRPAD detector and want to use the PerkinElmer Areadetector driver with it. So far it appears to work but we have noticed something we don’t understand about the ‘corrections’ part of the main medm gui.
I see in the PerkinElmer Areadetector medm gui that there is a button ( PV is something:PEAcquireOffset) to capture an offset correction which appears to capture to a TIFF file (if that plugin is enabled) using the filename specified for datafiles.
Question is that offset correction then simply held in memory and used for that session and needs to be captured fresh at the start of every session?
Also, there appears to be thing in the gui  to load and apply a previously captured file.
Is there a reason why using a previously captured one wouldn’t work? And is there a way to do that that just doesn’t appear on the gui? And a means of controlling the name of the captured offset file (other than the fields used for naming the normal datafiles which is what PEAcquireOffset  appears to do now?)
Thanks for any thoughts.
Terry
OFFICIAL
Prev: Re: SNMP in EPICS Miroslaw Dach via Tech-talk
Next: New devSNMP (NSCL/FRIB) release Priller, John via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Issue with FPGA based encoder box when running with EPICS 7.0.5 Michael Davidsaver via Tech-talk
Next: Re: offset correction in PerkinElmer AreaDetector [SEC=OFFICIAL] Mark Rivers via Tech-talk
