1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: New devSNMP (NSCL/FRIB) release
From: "Priller, John via Tech-talk" <[email protected]>
Date: Wed, 26 May 2021 09:55:19 +0000
All;
There is a new release 1.1.0.2 of our devSNMP package, adding support for SNMP v3 security.
https://groups.nscl.msu.edu/controls/
Direct links to the .zip and .html help file are here:
https://groups.nscl.msu.edu/controls/files/epics-snmp-1.1.0.2.zip
https://groups.nscl.msu.edu/controls/files/devSnmp.html
Please let me know of any issues.
A previous version 1.1.0.1 was up on our website over the weekend, if you happened to download that you definitely want to replace it.  I discovered a particularly nasty bug when it's used with net-snmnp v5.7.3 which is distributed for Debian 10 "buster".  That version of the net-snmp library assumes the void* context pointer passed for callbacks is a pointer to a 'synch_state' structure, because that's what snmpget/snmpset use, and it then steps on the first 4 bytes of whatever you've passed as the context pointer if the SNMP v3 passphrase or context name are wrong.  That was a lot of fun to track down, fun of the hair-pulling variety.
- JP
Prev: offset correction in PerkinElmer AreaDetector [SEC=OFFICIAL] CORNALL, Terry via Tech-talk
Next: Re: offset correction in PerkinElmer AreaDetector [SEC=OFFICIAL] Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: offset correction in PerkinElmer AreaDetector [SEC=OFFICIAL] Mark Rivers via Tech-talk
Next: AreaDetector stream encoding Daykin, Evan via Tech-talk
