1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: asyn bo record staying in INVALID DRIVER UDF
To: Ralph Lange <[email protected]>, Torsten Bögershausen <[email protected]>
Date: Thu, 27 May 2021 15:19:09 +0000
I'd like to help understand and/or fix this if it is a problem with asyn.
What versions of base and asyn are you using?
From: Tech-talk <[email protected]> on behalf of Torsten Bögershausen via Tech-talk <[email protected]>
Sent: Thursday, May 27, 2021 9:35 AM
To: Ralph Lange; EPICS Tech Talk
Hej again,
the alaram goes away, if the record is processed one more time.
We don't need to write to the PV, it is enough to disconnect-
and re-connect. Then the asyn callbacks will trigger, and the alarm
goes away.
This code:
IOC:m6-OpenClutchdevAsynInt32.c: static long initBo(boRecord *pr)
     devPvt *pPvt;
     int status;
     epicsInt32 value = 0xFFFFFFFF;
     status = initCommon((dbCommon *)pr,&pr->out,
         processCallbackOutput,interruptCallbackOutput,
interruptCallbackEnumBo,
         2, (char*)&pr->znam, NULL, &pr->zsv);
     fprintf(stdout, "%s/%s:%d %s status=%d\n",
             __FILE__, __FUNCTION__, __LINE__,
             pr->name, (int)status);
     if (status != INIT_OK) return status;
     pPvt = pr->dpvt;
     /* Read the current value from the device */
     status = pasynInt32SyncIO->read(pPvt->pasynUserSync,
                       &value, pPvt->pasynUser->timeout);
     fprintf(stdout, "%s/%s:%d  %s status=%d value=0x%X\n",
             pr->name, (int)status, value);
     if (status == asynSuccess) {
         pr->rval = value;
         return INIT_OK;
     return INIT_DO_NOT_CONVERT;
gives this prints:
../../asyn/devEpics/devAsynInt32.c/initBo:1203 IOC:IOC:m6-OpenClutch
status=0
../../asyn/devEpics/devAsynInt32.c/initBo:1211  IOC:IOC:m6-OpenClutch
status=10 value=0x0
So that the poller() hasn't been able to talk to the controller (yet).
And later, when the callback comes:
static long processBo(boRecord *pr)
     devPvt *pPvt = (devPvt *)pr->dpvt;
     int status;
     fprintf(stdout, "%s/%s:%d %s pPvt->newOutputCallbackValue=%d\n",
             pr->name, pPvt->newOutputCallbackValue);
     epicsMutexLock(pPvt->devPvtLock);
     if(pPvt->newOutputCallbackValue && getCallbackValue(pPvt)) {
         /* We got a callback from the driver */
       fprintf(stdout, "%s/%s:%d %s pPvt->result.status=%d\n",
               pr->name, pPvt->result.status);
         if (pPvt->result.status == asynSuccess) {
             pr->rval = pPvt->result.value;
             pr->val = (pr->rval) ? 1 : 0;
             pr->udf = 0;
../../asyn/devEpics/devAsynInt32.c/processBo:1225 IOC:m6-OpenClutch
pPvt->newOutputCallbackValue=1
../../asyn/devEpics/devAsynInt32.c/processBo:1232 IOC:m6-OpenClutch
pPvt->result.status=0
and here udf is set to zero.
But the alarm stays.
I don't know if this is a possible issue in base, asyn or somewhere else.
BR
/Torsten
On 5/27/21 4:12 PM, Torsten Bögershausen via Tech-talk wrote:
> Hej Ralph,
> I think it is the same-
> camonitor, second round:
> IOC:m6-OpenClutch 2021-05-27 15:51:06.243006 Closed UDF INVALID
> IOC:m6-OpenClutch.UDF 2021-05-27 15:51:06.243006 0 UDF INVALID
> IOC:m6-OpenClutch.STAT 2021-05-27 15:51:06.243006 UDF UDF INVALID
> IOC:m6-OpenClutch.SEVR 2021-05-27 15:51:06.243006 INVALID UDF INVALID
> [snipped warnings because of multihomed]
> And this is dbpr IOC:m6-OpenClutch 10
> ACKS: NO_ALARM      ACKT: YES           ASG :               ASP : PTR (nil)
> BKLNK: ELL 0 [(nil) .. (nil)]           BKPT: 00            COSV: NO_ALARM
> DESC: motor         DISA: 0             DISP: 0             DISS: NO_ALARM
> DISV: 1             DOL : CONSTANT      DPVT: PTR 0x1030ca0
> DSET: PTR 0x7fb1485072c0                DTYP: asynInt32     EVNT:
> FLNK: CONSTANT      HIGH: 0             IVOA: Continue normally
> IVOV: 0             LALM: 0             LCNT: 0             LSET: PTR
> 0xf143d0
> MASK: 0             MLIS: ELL 4 [0x7fb11802fb38 .. 0x7fb11802fc40]
> MLOK: b0 e8 fa 00 00 00 00 00           MLST: 0
> NAME: IOC:m6-OpenClutch                  NSEV: NO_ALARM
> NSTA: NO_ALARM      OLDSIMM: NO         OMSL: supervisory   ONAM: Open
> ORAW: 0             ORBV: 0             OSV : NO_ALARM
> OUT : INST_IO @asyn(MCU1,6)OpenClutch   PACT: 0             PHAS: 0
> PINI: NO            PPN : PTR (nil)     PPNR: PTR (nil)     PRIO: LOW
> PROC: 0             PUTF: 0             RBV : 0             RDES: PTR
> 0xb6e100
> RPRO: 0             RPVT: PTR 0x1030c70 RSET: PTR 0x7fb146f9e860
> RVAL: 0             SCAN: Passive       SDIS: CONSTANT      SDLY: -1
> SEVR: INVALID       SIML: CONSTANT      SIMM: NO            SIMPVT: PTR
> (nil)
> SIMS: NO_ALARM      SIOL: CONSTANT      SPVT: PTR (nil)     SSCN: <nil>
> STAT: UDF           TIME: 2021-05-27 15:51:06.243005887     TPRO: 0
> TSE : 0             TSEL: CONSTANT      UDF : 0             UDFS: INVALID
> VAL : 0             WDPT: PTR (nil)     ZNAM: Closed        ZSV : NO_ALARM
> /Torsten
> On 5/27/21 2:21 PM, Ralph Lange via Tech-talk wrote:
>> Hi Torsten,
>> On Thu, 27 May 2021 at 12:53, Torsten Bögershausen via Tech-talk
>> <[email protected] <mailto:[email protected]>> wrote:
>>     Asyn-Experts,
>>     I am chasing an interesting problem.
>>     For a motor, we have a clutch that can be opened under very
>>     special conditions, say service mode.
>>     We define it like this:
>>     The alarm seem to go away, if the record is processed one more time.
>>     (by disconnecting the IOC from the controller and re-establishing the
>>     connection).
>>     Is this a know phenomena ?
>>     Anything that can be done ?
>> How does the setup behave when using Channel Access?
>> (To see if it is a problem on the ASYN side or the QSRV side of the
>> database.)
>> Cheers,
>> ~Ralph
Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
Prev: Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Next: Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
