1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Make compilation having weird behavior
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Thu, 10 Jun 2021 12:29:20 +0000
Greetings, all
I am having trouble with the compilation of an IOC im editing: it uses modules which generate path conflicts in the form of the error:
Definition of MODULE conflicts with OTHER_MODULE support.
In this application a RELEASE file defines
MODULE = /usr/local/path/to/module
but OTHER_MODULE at /usr/local/path/to/other/module defines
MODULE = /usr/local/yet/a/different/path
The weird thing is, if i do the following steps:
1 -  make clean and make uninstall
2 - go to configure/CONFIG_SITE and set CHECK_RELEASE = WARN
3 - Go back to /TOP and compile via make
4 - Wait for the IOC to compile (this time it wont generate any error)
5 - back to /TOP, make clean and make uninstall
6 - back to configure/CONFIG_SITE set CHECK_RELEASE = YES
7 - Back to /TOP, compile via make
This last time, it will compile without generating any errors. Shouldn't it generate the same errors as before since CHECK_RELEASE is set to YES? Am i missing something?
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Prev: Re: Reading multiple lines from an asyn record Mark Rivers via Tech-talk
Next: Re: Writing to Waveform from CALC Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Writing to Waveform from CALC Mooney, Tim M. via Tech-talk
Next: Software Engineering Jobs at SNS White, Karen S. via Tech-talk
