1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Writing to Waveform from CALC
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Florian Feldbauer <[email protected]>
Date: Thu, 10 Jun 2021 13:13:19 +0000
I think I would use an aSub record for this task.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Florian Feldbauer via Tech-talk <[email protected]>
Sent: Thursday, June 10, 2021 5:00 AM
To: [email protected] <[email protected]>
Subject: Writing to Waveform from CALC
Hey all,
I have a question regarding waveform records. So far I never really
worked with waveform or any other array-type record.
The Situation is:
- Our DAQ collects the data coming from our Pixel sensor.
- Every 10s an IOC reads the stored data and fills a waveform record
with the hits (index of array = pixel, value = number of hits in the run)
- I use an image widget in Phoebus to display the hit map of the pixel
sensor
Now, for testing the sensors after bonding, we can perform charge
injections to individual pixels. We can also mask individual pixels if
they are too noisy.
As we need to always send the information for all pixels to the sensor,
I thought about using a second waveform record holding the per pixel
configuration.
Using the cursor X/Y PVs from the image widget in phoebus I could select
a pixel I want to inject a charge for testing (or I want to mask b/c
it's noisy) and get calculate the index within the waveform record from
these two PV's using a CALC record.
So now my actual question: Let's say I want to mask pixel 42, is it
possible to just write to val[41] from my config waveform record from a
CALC(OUT) record without touching the other values of the array?
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Writing to Waveform from CALC Florian Feldbauer via Tech-talk
Prev: Make compilation having weird behavior Marco A. Barra Montevechi Filho via Tech-talk
Next: RE: Problems configuring alarms with PvaPy KRL Baker - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Writing to Waveform from CALC Mark Rivers via Tech-talk
Next: Make compilation having weird behavior Marco A. Barra Montevechi Filho via Tech-talk
