1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Instructions on using manage-procs procServ and Conserver
From: "Smith, William via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Mon, 14 Jun 2021 07:42:34 +0000
Hi Michael,
I will open a ticket on github. In case anybody ever searches for something similar on techtalk I will also post what these two files look like below. Under ~/.config/procServ.d/ two files are created each time. One file called procserv-sampleIOC1.service is created, another called sampleIOC1.conf. The conf file looks correct:
[sampleIOC1]
command = /home/emil/Apps/epics/R7.0.4.1/work/ioc/TEST/sampleIOC/iocBoot/iocsampleIOC/st.cmd -c
chdir = /home/emil/Apps/epics/R7.0.4.1/work/ioc/TEST/sampleIOC/iocBoot/iocsampleIOC
port = 7010
However, the service file looks incorrect:
[Unit]
Description=procServ for sampleIOC1
After=network.target remote-fs.target
ConditionPathIsDirectory=/home/emil/Apps/epics/R7.0.4.1/work/ioc/TEST/sampleIOC/iocBoot/iocsampleIOC
[Service]
Type=simple
ExecStart=None --user sampleIOC1
RuntimeDirectory=procserv-sampleIOC1
StandardOutput=syslog
StandardError=inherit
SyslogIdentifier=procserv-sampleIOC1
[Install]
WantedBy=multi-user.target
Will
-----Original Message-----
Sent: Friday, June 11, 2021 8:26 PM
To: Smith, William <[email protected]>
Cc: [email protected]
Subject: Re: Instructions on using manage-procs procServ and Conserver
On 6/11/21 10:38 AM, Smith, William via Tech-talk wrote:
> cat /home/emil/.config/procServ.d/procserv-sampleIOC1.service
> [Service]
> Any idea what I am doing wrong?
The 'ExecStart' line is clearly not correct, so it looks like you've found a bug.
Would you like to open a ticket?  https://github.com/ralphlange/procServ
Please check to see if the config file under ~/.config/procServ.d/ has 'None' or 'st.cmd'.
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Instructions on using manage-procs procServ and Conserver Smith, William via Tech-talk
Re: Instructions on using manage-procs procServ and Conserver Michael Davidsaver via Tech-talk
Prev: RE: Instructions on using manage-procs procServ and Conserver Smith, William via Tech-talk
Next: Re: Best way to properly "synchronize" records between two IOCs Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Instructions on using manage-procs procServ and Conserver Michael Davidsaver via Tech-talk
Next: Re: Instructions on using manage-procs procServ and Conserver Hu, Yong via Tech-talk
