1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS-MODBUS plus SNC Sequencer in and IOC
To: Josh Fiddler <[email protected]>
Date: Tue, 15 Jun 2021 02:13:57 +0000
> Having configured a TCP driver in Koyo1.cmd, and checked RELEASE for the correct paths, running ./st.cmd closes silently.
Did you edit st.cmd?  The distributed version does not contain a line with #! and the name of an application.
You will need to edit st.cmd to select Koyo1.cmd rather than sim1.cmd.
Then run the test IOC from the modbus/iocBoot/iocTest directory by typing:
../../bin/linux-x86_64/modbusApp st.cmd
From: Tech-talk <[email protected]> on behalf of Josh Fiddler via Tech-talk <[email protected]>
Sent: Monday, June 14, 2021 4:54 PM
To: [email protected]
Subject: EPICS-MODBUS plus SNC Sequencer in and IOC
Hey EPICS masters,
I'm stuck. As the subject suggests, I'm trying to create an application to communicate with a DL205 plc via Modbus TCP and control via a state machine.
I've not been able to get the modbusApp testIOC running. I've followed the instructions and suggestions in the docs. Having configured a TCP driver in Koyo1.cmd, and checked RELEASE for the correct paths, running ./st.cmd closes silently.
How do I make use of the .template files to create the database for the sequencer?
Josh
[https://lh3.googleusercontent.com/pCXhB1osnZ8TglhO9_m1MnGO1UXpqIVyn3pzDiZt4StUUeysZvOKP8EQy6RDBcPzbl1ZKgblesdl_Ks6TSGci5vpDUD4a79y_-rjxZcPxpaPSiY6nez1TI-DsKu8MJVOfpHD55ln]
Josh Fiddler
Fusion Technician
+1-450-245-1065
www.f.energy<http://www.f.energy> [https://lh6.googleusercontent.com/PYvuP7XKjlBS5BrntaZuZbPM4dUb2Upc639tl3oAYdYDGMhSYrIiEcakGBN-AYJ0uH_ubwc8ofqAoAw3KNB3W4c4ozO5GUepy-6alVnrA7wZQ4hlSFPCFLNGevCqLQnT4G70rvpG]
Linkedin<https://www.linkedin.com/in/josh-fiddler/>
Re: EPICS-MODBUS plus SNC Sequencer in and IOC Mark Rivers via Tech-talk
EPICS-MODBUS plus SNC Sequencer in and IOC Josh Fiddler via Tech-talk
Prev: EPICS-MODBUS plus SNC Sequencer in and IOC Josh Fiddler via Tech-talk
Next: Re: EPICS-MODBUS plus SNC Sequencer in and IOC Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
