1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Re: Get timestamp from another IOC
From: Adrian Martinez via Tech-talk <[email protected]>
To: Zhang Yuliang <[email protected]>
Cc: [email protected]
Date: Wed, 16 Jun 2021 16:49:12 +0200
Hello Yuliang,
I've used 'dbr' command on IOC1 and this is the out for Timestamp_from_IOC1:
ioc > dbpr MBT-RBN:TMG-EVR-01:Timestamp_from_IOC1 10
ACKS: NO_ALARM      ACKT: YES           APST: On Change     ASG:
ASP: (nil)          BKPT: 00            DESC:               DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DPVT: 0x153cf30
DSET: 0x7f5fc4122160                    DTYP: Obj Prop string
EVNT:               FLNK:DB_LINK MBT-RBN:TMG-EVR-01:TimeErr-I
INP:INST_IO @OBJ=EVR-MTCA, PROP=NextSecond                  LCNT: 0
LSET: 0x1410530
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: f0 85 50 01 00 00 00 00           MPST: On Change
Timestamp_from_IOC1   NSEV: NO_ALARM      NSTA: NO_ALARM
OVAL: Sun, 07 Feb 2106 06:28:16         PACT: 0             PHAS: 0
PINI: NO            PPN: (nil)          PPNR: (nil)         PRIO: LOW
PROC: 0             PUTF: 0             RDES: 0x1242bc0     RPRO: 0
RSET: 0x7f5fc3ca6560                    SCAN: 1 second      SDIS:CONSTANT
SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM
SIOL:CONSTANT       SPVT: 0x1558ce0     STAT: NO_ALARM      SVAL:
TIME: 2021-06-16 14:47:16.997443401     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 1              UDFS: INVALID
The SCAN field is 1s, VAL field never changes but the TIME field of the PV does.
Thanks, Adrián
El mié, 16 jun 2021 a las 16:13, Zhang Yuliang (<[email protected]>) escribió:
Hello Adrian,
Please paste the code of record "$(Y):Timestamp_from_IOC1". Can you make sure the record "$(Y):Timestamp_from_IOC1" processed periodically or only once?
Yuliang
-----原始邮件-----
发件人:"Adrian Martinez" <[email protected]>
发送时间:2021-06-16 18:38:42 (星期三)
收件人: "Zhang Yuliang" <[email protected]>
抄送: [email protected]
主题: Re: Get timestamp from another IOC
Hello Yuliang,
I have deleted CP but It does not work. The PV "TimeStr" is still not updated.
Thanks, Adrián.
El mié, 16 jun 2021 a las 12:09, Zhang Yuliang (<[email protected]>) escribió:
Hello Adrian,
Try to delete CP in line "field(TSEL, "$(Y):Timestamp_from_IOC1.TIME CP MS")".
Yuliang
-----原始邮件-----
发件人:"Adrian Martinez via Tech-talk" <[email protected]>
发送时间:2021-06-16 18:03:22 (星期三)
收件人: [email protected]
抄送:
主题: Get timestamp from another IOC
Hello,
I'm trying to get the timestamp from another IOC (we will call it "IOC1") using the following DB records:
record(stringin, "$(user):TimeStr") {
    field(DTYP, "Soft Timestamp")
    field(INP, "@%s")
    field(SCAN, ".2 second")
record(ao, "$(user):Time"){
     field(DTYP, "asynInt32")
     field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))my_time")
record(calcout, "$(user):TimeCalc"){
     field(OUT, "$(user):Time PP")
     field(CALC, "A")
     field(INPA, "$(user):TimeStr.VAL CP MS")
     field(PINI, "YES")
At the startup of IOC2 I am able to get the timestamp from IOC1 but only once. The PV "TimeStr" doesn't update.
Can someone help me with this task?
Thanks in advance, Adrián.
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
http://sevensols.com
Adrián Martínez Múnera
Embedded Software Engineer
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it.
Adrián Martínez
Seven Solutions
Mail: [email protected]
www.sevensols.com
Re: Get timestamp from another IOC Johnson, Andrew N. via Tech-talk
Re: Re: Get timestamp from another IOC Hu, Yong via Tech-talk
Re: Get timestamp from another IOC Michael Davidsaver via Tech-talk
Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Prev: Re: Get timestamp from another IOC Hu, Yong via Tech-talk
Next: Re: Get timestamp from another IOC Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
