1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: PINI field for lsi record doesn't seem to work?
From: "Wang, Andrew via Tech-talk" <[email protected]>
Date: Fri, 18 Jun 2021 17:45:52 +0000
Hi Mark,
Ah shoot, I totally missed that. Thanks for pointing that out.
Is there an alternative approach?
Andy
-----Original Message-----
Sent: Friday, June 18, 2021 10:39 AM
To: Wang, Andrew <[email protected]>
Cc: [email protected]
Subject: Re: PINI field for lsi record doesn't seem to work?
Hi Andy,
If you look at the record reference manual for the lsi record here
https://urldefense.us/v3/__https://epics.anl.gov/base/R7-0/4-docs/lsiRecord.html__;!!G2kpM7uM-TzIFchu!itLLdJGxVkYXYovQyAVT9J7NWjWci0hie9PaCqBFlICHSo37DCv0iUTZ85cVFoCmA2I$
<https://urldefense.us/v3/__https://epics.anl.gov/base/R7-0/4-docs/lsiRecord.html__;!!G2kpM7uM-TzIFchu!itLLdJGxVkYXYovQyAVT9J7NWjWci0hie9PaCqBFlICHSo37DCv0iUTZ85cVFoCmA2I$ >you will see that the VAL field has DCT=NO.  I believe that means you cannot initialize the VAL field in your database file, but I could be mistaken.  Did you see any error or warning when you loaded the database file?
From: Tech-talk <[email protected]> on behalf of Wang, Andrew via Tech-talk <[email protected]>
Sent: Friday, June 18, 2021 12:31 PM
To: [email protected]
Subject: PINI field for lsi record doesn't seem to work?
All,
I have a simple lsi record shown below.
record(lsi, "joke_record")
              field(SIZV,  128)
              field(VAL,  "If you read this, tell me a funny joke")
              field(PINI, "YES")
When I start up the IOC and do a caget on "joke_record", I do not get the initial value. Feel like there is something very simple I forgot...
Andy
PINI field for lsi record doesn't seem to work? Wang, Andrew via Tech-talk
Re: PINI field for lsi record doesn't seem to work? Mark Rivers via Tech-talk
Prev: Re: PINI field for lsi record doesn't seem to work? Johnson, Andrew N. via Tech-talk
Next: RE: PINI field for lsi record doesn't seem to work? Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: PINI field for lsi record doesn't seem to work? Mark Rivers via Tech-talk
Next: Re: PINI field for lsi record doesn't seem to work? Johnson, Andrew N. via Tech-talk
