1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: PINI field for lsi record doesn't seem to work?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: "Wang, Andrew" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Fri, 18 Jun 2021 18:40:40 +0000
On Jun 18, 2021, at 12:38 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
If you look at the record reference manual for the lsi record here
https://epics.anl.gov/base/R7-0/4-docs/lsiRecord.html
<https://epics.anl.gov/base/R7-0/4-docs/lsiRecord.html> you will see that the VAL field has DCT=NO.  I believe that means you cannot initialize the VAL field in your database file, but I could be mistaken.
Actually having DCT=No won’t prevent you from setting a field in your .db file; you won’t get an error message and dbLoadRecords() will write that value to the field if it can, but it’s generally an indication that the field isn't intended to be set by hand and nothing different is likely to happen if you do so. Setting the PROC field of any record demonstrates this nicely.
The DCT column in the record reference tables shows as No when the field has no promptgroup() setting in its Record.dbd file, implying that there’s no point in an EPICS Database Configuration tool such as VisualDCT or the original dct showing it to the user at design time.
In this particular case both EPICS 7.0 and 3.15 give me an error when trying to set lsi.VAL because the field is actually DBF_NOACCESS at dbLoadRecords() time, the record support code must be initialized and a buffer allocated for it for the field to become accessible. I’m a bit surprised that Andy didn’t get the same result...
- Andrew
Complexity comes for free, simplicity you have to work for.
PINI field for lsi record doesn't seem to work? Wang, Andrew via Tech-talk
Re: PINI field for lsi record doesn't seem to work? Mark Rivers via Tech-talk
Prev: RE: PINI field for lsi record doesn't seem to work? Wang, Andrew via Tech-talk
Next: Using autosave to restore device settings after a reset without rebooting IOC Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: PINI field for lsi record doesn't seem to work? Johnson, Andrew N. via Tech-talk
