1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: [EXTERNAL] StreamDevice support problem: Cannot find a bus named 'L0' for...
From: "Hartman, Steven via Tech-talk" <tech-talk at aps.anl.gov>
To: Hasan SANSAR <hasansansar at gmail.com>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 22 Jun 2021 13:40:18 +0000
On Jun 22, 2021, at 9:28 AM, Hasan SANSAR via Tech-talk <tech-talk at aps.anl.gov> wrote:
drvAsynIPPortConfigure("L0","10.97.4.4:8003",0,0,0)
2021/06/22 16:12:24.130 L0 -1 autoConnect could not connect: Can't connect to 10.97.4.4:8003: Connection refused
“Connection refused” indicates that you are not able to reach TCP port 8003 at 10.97.4.4. Verify that you are using the correct address and port number and the device is online and listening on that port. Also check if there are any firewalls that may be blocking the connection.
You can test from the same host that is running the IOC with
  telnet 10.97.4.4 8003
Steven Hartman
hartmansm at ornl.gov
StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Mark Rivers via Tech-talk
Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Prev: Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Next: Timestamp not updating with pvput and PvaPy KRL Baker - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
ANJ, 22 Jun 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
