1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: questions about the motor homing sequence
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Tue, 29 Jun 2021 15:13:26 +0000
Hello EPICS-community,
I'm trying to write an EPICS-motor device support for the PEGASUS Rotation- and Linear-Stages from Micos. I'm using the Hydra and Corvus motor-support from the main EPICS-motor module as a template.
I have the following problem when writing the homing sequence for the Rotation-stages: after sending the homing-command string
    sprintf(pC_->outString_, "1 0 %i setsw 1 1 %i setsw 1 0 %i sncal", (axisNo_ + 1), (axisNo_ + 1), (axisNo_ + 1));
    pC_->writeController();
I need to wait until reference-drive finished aka. the motor stopped, so I can switch off the Limit-switches with the following command:
    sprintf(pC_->outString_, "2 0 %i setsw 2 1 %i setsw", (axisNo_ + 1), (axisNo_ + 1));
So far I could resolve this problem by implementing a while loop with an epicsThreadSleep(1.) asking the controller about its moving bit and once it set to 1 (done), execute the desired command. Here is my complete code of the homing function:
asynStatus SMCpegasusAxis::home(double baseVelocity, double slewVelocity, double acceleration, int forwards)
  asynStatus status;
  int done = 0;
  int axisStatus = -1;
  double position = 0.0;
  // static const char *functionName = "SMCpegasusAxis::home";
  status = sendAccelAndVelocity(acceleration, slewVelocity);
  if (forwards) {
    // Read the status of this motor
    sprintf(pC_->outString_, "%i nst", (axisNo_ + 1));
    pC_->writeReadController();
    // The response string is an int
    axisStatus = atoi( (char *) &pC_->inString_);
    do
        // Read the current motor position
        sprintf(pC_->outString_, "%i np", (axisNo_ + 1));
        // The response string is a double
        position = atof( (char *) &pC_->inString_);
        setDoubleParam(pC_->motorPosition_, (position / axisRes_) );
        setDoubleParam(pC_->motorEncoderPosition_, (position / axisRes_) );
        // Check the moving bit
        done = !(axisStatus & 0x1);
        setIntegerParam(pC_->motorStatusDone_, done);
        setIntegerParam(pC_->motorStatusMoving_, !done);
        epicsThreadSleep(1.);
    } while (done == 0);
    //epicsThreadSleep(3.);
  } else {
    //still ToDo the Home Run backward
  status = pC_->writeController();
  return status;
Having a while-loop with an threadSleep is kind of bad coding I think, so I'm wondering if someone knows a better solution?
PS: I'm also trying to update the motor position during the while-loop (it is the "// Read the current motor position" passage). I see the correct position in the asyn communication but the .RBV value of the motor record won't update. I guess, this can only be done from the poll-function?
Best regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
Re: questions about the motor homing sequence Mark Rivers via Tech-talk
Prev: areaDetector ADEiger R3-0 released Mark Rivers via Tech-talk
Next: Re: questions about the motor homing sequence Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
