1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: questions about the motor homing sequence
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Sintschuk, Michael" <michael.sintschuk at bam.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 29 Jun 2021 16:13:18 +0000
Hi Michael,
> Having a while-loop with an threadSleep is kind of bad coding I think, so I'm wondering if someone knows a better solution?
You can take that code and run it in a separate thread.  You need to call lock() on entrance, and then release the lock around the sleep.
unlock();
epicsThreadSleep(1);
lock();
> PS: I'm also trying to update the motor position during the while-loop (it is the "// Read the current motor position" passage). I see the correct position in the asyn communication but the .RBV value of the motor record won't update. I guess, this can only be done from the poll-function?
The poller should continue to run normally if you run the home sequence in a separate thread and call unlock() as shown above.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sintschuk, Michael via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, June 29, 2021 10:13 AM
To: tech-talk at aps.anl.gov
Subject: questions about the motor homing sequence
Hello EPICS-community,
I'm trying to write an EPICS-motor device support for the PEGASUS Rotation- and Linear-Stages from Micos. I'm using the Hydra and Corvus motor-support from the main EPICS-motor module as a template.
I have the following problem when writing the homing sequence for the Rotation-stages: after sending the homing-command string
    sprintf(pC_->outString_, "1 0 %i setsw 1 1 %i setsw 1 0 %i sncal", (axisNo_ + 1), (axisNo_ + 1), (axisNo_ + 1));
    pC_->writeController();
I need to wait until reference-drive finished aka. the motor stopped, so I can switch off the Limit-switches with the following command:
    sprintf(pC_->outString_, "2 0 %i setsw 2 1 %i setsw", (axisNo_ + 1), (axisNo_ + 1));
So far I could resolve this problem by implementing a while loop with an epicsThreadSleep(1.) asking the controller about its moving bit and once it set to 1 (done), execute the desired command. Here is my complete code of the homing function:
asynStatus SMCpegasusAxis::home(double baseVelocity, double slewVelocity, double acceleration, int forwards)
  asynStatus status;
  int done = 0;
  int axisStatus = -1;
  double position = 0.0;
  // static const char *functionName = "SMCpegasusAxis::home";
  status = sendAccelAndVelocity(acceleration, slewVelocity);
  if (forwards) {
    // Read the status of this motor
    sprintf(pC_->outString_, "%i nst", (axisNo_ + 1));
    pC_->writeReadController();
    // The response string is an int
    axisStatus = atoi( (char *) &pC_->inString_);
    do
        sprintf(pC_->outString_, "%i np", (axisNo_ + 1));
        // The response string is a double
        position = atof( (char *) &pC_->inString_);
        setDoubleParam(pC_->motorPosition_, (position / axisRes_) );
        setDoubleParam(pC_->motorEncoderPosition_, (position / axisRes_) );
        // Check the moving bit
        done = !(axisStatus & 0x1);
        setIntegerParam(pC_->motorStatusDone_, done);
        setIntegerParam(pC_->motorStatusMoving_, !done);
        epicsThreadSleep(1.);
    } while (done == 0);
    //epicsThreadSleep(3.);
  } else {
    //still ToDo the Home Run backward
  status = pC_->writeController();
  return status;
Best regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
michael.sintschuk at bam.de<mailto:michael.sintschuk at bam.de>
AW: questions about the motor homing sequence Sintschuk, Michael via Tech-talk
Prev: questions about the motor homing sequence Sintschuk, Michael via Tech-talk
Next: porting IOCs from Linux to RTEMS Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Next: AW: questions about the motor homing sequence Sintschuk, Michael via Tech-talk
ANJ, 12 Jul 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
