1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: AW: questions about the motor homing sequence
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Mon, 12 Jul 2021 16:19:21 +0000
Hi Mark,
I forgot to reply to all the last time, so I copy pasted your solution into this mail.
Yes, your second solution works quite well. Even though I put the " homingInProgress " variable into the header file. I pushed it to git:
https://github.com/MichaS-git/motorMicos
but it is the very first version and still needs further development and testing.
Thanks for the explanation!
Michael
>However, it works to compile with "pC_->lock();" and "pC_->unlock();". But it has no effect on the record-update.
Yes, my mistake.  You need to use pC_->lock()/unlock().
To create a new thread you need to call epicsThreadCreate().  You pass it the address of a function to be called, and a void* pointer, which in this case would be “this”.
However, I just realized there is probably a simpler way to solve this problem.
-	In your SMCpegasusAxis class create a new private bool variable called homingInProgress or something like that.
-	In SMCpegasusAxis::home only do the following:
o	set that homingInProgress variable to true
o	Start the homing operation
-	Change your SMCpegasusAxis::poll() routine so it does the following:
o	If homingInProgress is true, and if the motor makes the transition from moving to not moving (homing is complete) then do the following:
	Set homingInProgress to false
	Send the string that needs to be sent to the controller when homing is complete
Does that seem like it would work?
Sent: Wednesday, June 30, 2021 8:18 AM
To: Mark Rivers
Hi Mark,
> You can take that code and run it in a separate thread.  You need to call lock() on entrance, and then release the lock around the sleep.
By calling lock() the separate thread is created or do I need to write the separate thread by my own, like a separate function? (sorry, I'm new to c++ )
When I try to compile my code with the the "lock();" and "unlock();" lines I get the error: 'lock' was not declared in this scope.
Michael
-----Ursprüngliche Nachricht-----
Von: Mark Rivers <[email protected]>
Gesendet: Dienstag, 29. Juni 2021 18:13
An: Sintschuk, Michael <[email protected]>
Cc: [email protected]
Betreff: Re: questions about the motor homing sequence
Hi Michael,
> Having a while-loop with an threadSleep is kind of bad coding I think, so I'm wondering if someone knows a better solution?
unlock();
epicsThreadSleep(1);
lock();
> PS: I'm also trying to update the motor position during the while-loop (it is the "// Read the current motor position" passage). I see the correct position in the asyn communication but the .RBV value of the motor record won't update. I guess, this can only be done from the poll-function?
The poller should continue to run normally if you run the home sequence in a separate thread and call unlock() as shown above.
From: Tech-talk <[email protected]> on behalf of Sintschuk, Michael via Tech-talk <[email protected]>
Sent: Tuesday, June 29, 2021 10:13 AM
To: [email protected]
Subject: questions about the motor homing sequence
Hello EPICS-community,
I'm trying to write an EPICS-motor device support for the PEGASUS Rotation- and Linear-Stages from Micos. I'm using the Hydra and Corvus motor-support from the main EPICS-motor module as a template.
I have the following problem when writing the homing sequence for the Rotation-stages: after sending the homing-command string
    sprintf(pC_->outString_, "1 0 %i setsw 1 1 %i setsw 1 0 %i sncal", (axisNo_ + 1), (axisNo_ + 1), (axisNo_ + 1));
    pC_->writeController();
I need to wait until reference-drive finished aka. the motor stopped, so I can switch off the Limit-switches with the following command:
    sprintf(pC_->outString_, "2 0 %i setsw 2 1 %i setsw", (axisNo_ + 1), (axisNo_ + 1));
So far I could resolve this problem by implementing a while loop with an epicsThreadSleep(1.) asking the controller about its moving bit and once it set to 1 (done), execute the desired command. Here is my complete code of the homing function:
asynStatus SMCpegasusAxis::home(double baseVelocity, double slewVelocity, double acceleration, int forwards) {
  asynStatus status;
  int done = 0;
  int axisStatus = -1;
  double position = 0.0;
  // static const char *functionName = "SMCpegasusAxis::home";
  status = sendAccelAndVelocity(acceleration, slewVelocity);
  if (forwards) {
    // Read the status of this motor
    sprintf(pC_->outString_, "%i nst", (axisNo_ + 1));
    pC_->writeReadController();
    // The response string is an int
    axisStatus = atoi( (char *) &pC_->inString_);
    do
        sprintf(pC_->outString_, "%i np", (axisNo_ + 1));
        // The response string is a double
        position = atof( (char *) &pC_->inString_);
        setDoubleParam(pC_->motorPosition_, (position / axisRes_) );
        setDoubleParam(pC_->motorEncoderPosition_, (position / axisRes_) );
        // Check the moving bit
        done = !(axisStatus & 0x1);
        setIntegerParam(pC_->motorStatusDone_, done);
        setIntegerParam(pC_->motorStatusMoving_, !done);
        epicsThreadSleep(1.);
    } while (done == 0);
    //epicsThreadSleep(3.);
  } else {
    //still ToDo the Home Run backward
  status = pC_->writeController();
  return status;
Best regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]<mailto:[email protected]>
questions about the motor homing sequence Sintschuk, Michael via Tech-talk
Re: questions about the motor homing sequence Mark Rivers via Tech-talk
Prev: Re: Kubernetes for EPICS IOCs Josh Fiddler via Tech-talk
Next: Re: Event Recordings -- Epics Spring 2021 Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: questions about the motor homing sequence Mark Rivers via Tech-talk
Next: porting IOCs from Linux to RTEMS Siddons, David via Tech-talk
