1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Block CAPUT to not be able to modify PV value
From: Adrian Martinez via Tech-talk <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 15 Jul 2021 08:25:23 +0200
Hello Mark,
I mean that I am not able to change the PV value using a text input in CSS (SDIS and DISV fields work fine) but, if I use caput UCrTcrLimitUsSet or caput UCrTcrLimitUsSet, I can change these values. Using caget I can confirm it:
$ caput SL-INJ-RFQ:LRF-CAV-1:UCrTcrLimitUsSet 1
Old : SL-INJ-RFQ:LRF-CAV-1:UCrTcrLimitUsSet 0
New : SL-INJ-RFQ:LRF-CAV-1:UCrTcrLimitUsSet 1
$ caget SL-INJ-RFQ:LRF-CAV-1:UCrTcrLimitUsSet
Thanks, Adrián.
El mié, 14 jul 2021 a las 16:07, Mark Rivers (<[email protected]>) escribió:
Being able to set with caput but not with CSS does not make sense to me. Please send the output of caput followed by caget.
Sent from my iPhone
On Jul 14, 2021, at 8:59 AM, Adrian Martinez via Tech-talk <[email protected]> wrote:
Hello,
I need to block the setting function for some PVs. I was using SDIS and DISV fields:
record(ao, "$(user):UCrTcrLimitUsSet")
field(DTYP, "asynInt32")
field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))ucr_tcr_us")
field(VAL,  "0")
field(EGU,  "us")
field(HOPR, "10000")
field(LOPR, "0")
field(DRVH, "10000")
field(DRVL, "0")
field(SDIS, "$(user):StartUpOn.VAL CP MS")
field(DISV, "0")
info(autosaveFields, "VAL")
record(calc, "$(user):UCrTcrLimitUsRd")
field(CALC, "((A / 10^-6) / 300000000)")
field(INPA, "$(user):UCrTcrLimRd.VAL CP MS")
field(EGU,  "us")
field(DISV, "0")
This only works for the graphical user interface CSS (I am not able to modify the Pv value in the gui) but, if I use CAPUT, I can modify the PV value.
Is there any way to completely block setting function?
Thanks in advance, Adrián.
Adrián Martínez
Embedded Software Engineer
        Seven Solutions
Mail: [email protected]<mailto:[email protected]>
www.sevensols.com<http://www.sevensols.com/>
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
Adrián Martínez
Seven Solutions
www.sevensols.com
Block CAPUT to not be able to modify PV value Adrian Martinez via Tech-talk
Re: Block CAPUT to not be able to modify PV value Mark Rivers via Tech-talk
Prev: Re: Block CAPUT to not be able to modify PV value Adrian Martinez via Tech-talk
Next: Re: Block CAPUT to not be able to modify PV value Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Block CAPUT to not be able to modify PV value Mark Rivers via Tech-talk
Next: Compiling motor R7-2-2 against EPICS 7.0.6 Andy Foster via Tech-talk
