1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Block CAPUT to not be able to modify PV value
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Adrian Martinez <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 15 Jul 2021 16:55:33 +0000
Hi Adrián,
On Jul 15, 2021, at 12:45 AM, Adrian Martinez <[email protected]> wrote:
I knew the DISP field but I need to disable UCrTcrLimitUsSet and UCrTcrLimitUsRd when StartUpOn =! 1, not all the time.
Is it possible with DISP?
Yes, you have an EPICS database at your disposal which was designed to do that kind of thing. You would need to add two records, one to invert the value from StartUpOn (since it’s 0 when you want to disable those records) and the second to copy the result into the DISP fields of the records to be disabled. I would probably use a dfanout for the latter, but a seq record would also work. Something like this should do it:
record(calc, "$(user):UCrTcrDISP")
  field(CALC, "!A")
  field(INPA, "$(user):StartUpOn CP")
  field(FLNK, "$(user):UCrTcrDisable")
record(dfanout, "$(user):UCrTcrDisable")
  field(DOL, "$(user):UCrTcrDISP")
  field(OMSL, "closed_loop")
  field(SELM, "All")
  field(OUTA, "$(user):UCrTcrLimitUsSet.DISP MS")
  field(OUTB, "$(user):UCrTcrLimitUsRd.DISP MS")
The CP flag on the calc INPA link will cause it to process whenever the value of StartUpOn changes. Its forward-link field will then trigger the dfanout to copy the inverted value to the DISP fields of the other records, thus preventing them from being modified by any CA clients while StartUpOn is zero (although DISP will not prevent those records from processing if they get triggered by some other means). You can disable up to 6 more records with this if you want, using the dfanout links OUTC through OUTH.
- Andrew
El mié, 14 jul 2021 a las 16:04, Johnson, Andrew N. (<[email protected]>) escribió:
Hi Adrian,
Take a look at the DISP field (described here), when non-zero it disables puts to any field of the record except for the DISP field itself.
- Andrew
On Jul 14, 2021, at 8:59 AM, Adrian Martinez via Tech-talk <[email protected]> wrote:
Hello,
I need to block the setting function for some PVs. I was using SDIS and DISV fields:
record(ao, "$(user):UCrTcrLimitUsSet")
field(DTYP, "asynInt32")
field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))ucr_tcr_us")
field(VAL,  "0")
field(EGU,  "us")
field(HOPR, "10000")
field(LOPR, "0")
field(DRVH, "10000")
field(DRVL, "0")
field(SDIS, "$(user):StartUpOn.VAL CP MS")
field(DISV, "0")
info(autosaveFields, "VAL")
record(calc, "$(user):UCrTcrLimitUsRd")
field(CALC, "((A / 10^-6) / 300000000)")
field(INPA, "$(user):UCrTcrLimRd.VAL CP MS")
field(EGU,  "us")
field(DISV, "0")
This only works for the graphical user interface CSS (I am not able to modify the Pv value in the gui) but, if I use CAPUT, I can modify the PV value.
Is there any way to completely block setting function?
Thanks in advance, Adrián.
Adrián Martínez
Embedded Software Engineer
Seven Solutions
Mail: [email protected]
www.sevensols.com
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
Complexity comes for free, simplicity you have to work for.
Adrián Martínez
Seven Solutions
www.sevensols.com
Re: Block CAPUT to not be able to modify PV value Adrian Martinez via Tech-talk
Re: Block CAPUT to not be able to modify PV value Johnson, Andrew N. via Tech-talk
Prev: Re: Block CAPUT to not be able to modify PV value Adrian Martinez via Tech-talk
Next: Compiling motor R7-2-2 against EPICS 7.0.6 Andy Foster via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Block CAPUT to not be able to modify PV value Adrian Martinez via Tech-talk
