1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: linking in IOC makefile for RTEMS
From: "Siddons, David via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 19 Jul 2021 12:34:40 +0000
Hi Michael,
   OK, thanks for the clarification. I'll try that.
What I want to do is make EPICS-aware detectors which are as self-contained as possible, and as easy to deploy as possible. Ideally, one would turn on the detector, plug it into any ethernet and be ready to go. A detector appliance, if you wish. Requiring NFS mounts or TFTP servers goes against that goal. Using Linux on Zynq we have succeeded in this goal for some time. In fact, many years ago I built an RTEMS / EPICS system for the Coldfire uC5272, which was the basis for Eric's uC5282 BSP, and which used Eric's tarball approach. Those systems were deployed to several institutions and, as far as I know, are still going. Recently I read that RTEMS had significantly improved in capabilities and ease of deployment, so I wanted to see if those Linux apps could be ported. I'm convinced that is possible using remote filesystems, but I would really like them to be stand-alone.
Pete.
Sent: Sunday, July 18, 2021 9:56 PM
To: Siddons, David <[email protected]>
Cc: EPICS tech-talk <[email protected]>; Johnson, Andrew N. <[email protected]>; [email protected] <[email protected]>
Hi Pete,
On 7/18/21 11:41 AM, Siddons, David wrote:
> Hi Michael,
>    OK, you are right. That fixed the symbol problem and it now tries to mount the filesystem. Booting the resultant image I get:
> The image was generated using the attached script, make-tarball.sh, and the current Makefile is also attached.
I think you are confusing the two different ways which the rtems_init.c
code in Base has for populating an in memory file system.
The 'epicsRtemsFSImage' weak symbol can only be used with code generated
by the 'epicsMakeMemFs.pl' script.  The output of this script is _not_
a tar file.  So linking in a tar file will not work (as you find).
For example:
> $(EPICS_BASE)/bin/linux-x86_64/epicsMakeMemFs.pl nottarball.c epicsRtemsFSImage README Makefile test.c
The resulting nottarball.c will contain the three files README Makefile test.c,
which will be unpacked into '/'.
The other weak symbol '_DownloadLocation' is meant to be a tar file, although as I found,
this probably only worked for the uC5282 target.  Without changes to Base, this probably
won't be useful for you with any other RTEMS target.
https://epics.anl.gov/core-talk/2021/msg00880.php
Maybe we should revisit why you aren't able to use a network file system?  Being an IOC,
I assume you target will have network access?
> Pete.
> *From:* Michael Davidsaver <[email protected]>
> *Sent:* Saturday, July 17, 2021 2:44 PM
> *To:* Siddons, David <[email protected]>
> *Cc:* EPICS tech-talk <[email protected]>; Johnson, Andrew N. <[email protected]>
> *Subject:* Re: linking in IOC makefile for RTEMS
> On 7/16/21 12:47 PM, Siddons, David via Tech-talk wrote:
>> Hi Andrew,
>>   It doesn't seem to. The file is clearly compiled and included in the support library:
>> /home/peter/quick-start/rtems/5/bin/arm-rtems5-ar rc   libmyexampleSupport.a    xxxRecord.o devXxxSoft.o dbSubExample.o devmyexampleVersion.o myexampleHello.o initTrace.o tarball.o
> I'm not sure my 'epicsRtemsFSImage' trick will work from a library.
> Try moving tarball.c to myexample_SRCS.
>> myexample_SRCS += tarball.c
> And I think you can just remove '..._SRCS += tarball.h'.
> It's probably not doing anything helpful.
>> arm-rtems5-nm libmyexampleSupport.a |grep epicsRtems
>> 00000000 R epicsRtemsFSImage
>> 00000000 R epicsRtemsFSImage_size
>> but not in the myexample executable:
>> peter@peter-OptiPlex-7070:~/test_ioc/bin/RTEMS-beagleboneblack$ arm-rtems5-nm myexample |grep epicsRtems
>> 8060306c V epicsRtemsFSImage
>> which is the weak symbol.
>> Pete.
>> *From:* Johnson, Andrew N. <[email protected]>
>> *Sent:* Friday, July 16, 2021 3:21 PM
>> Hi Pete,
>> Just an idea, does it make any difference if you remove the tarball.h file from your _SRCS variable (you shouldn’t include .h files in _SRCS anyway, if you want to install them they go into INC instead)?
>> - Andrew
>>> On Jul 16, 2021, at 2:08 PM, Siddons, David via Tech-talk <[email protected] <mailto:[email protected] <mailto:[email protected]>>> wrote:
>>> I have an RTEMS test IOC (generated using makeBaseApp) to which I've added a source file which declares a large array (actually, a compiled-in file system). The Makefile has:
>>> # rather than directly into the IOC application, that
>>> # causes problems on Windows DLL builds
>>> myexampleSupport_SRCS += dbSubExample.c
>>> myexampleSupport_SRCS += devmyexampleVersion.c
>>> myexampleSupport_SRCS += myexampleHello.c
>>> myexampleSupport_SRCS += initTrace.c
>>> myexampleSupport_SRCS += tarball.h
>>> myexampleSupport_SRCS += tarball.c
>>> where the tarball files are my additions. The C file contains:
>>>  *  Declarations for C structure representing binary file epicsRtemsFSImage
>>>  *  WARNING: Automatically generated -- do not edit!
>>> #include <sys/types.h>
>>> const unsigned char epicsRtemsFSImage[] = {
>>>   0x74, 0x61, 0x72, 0x62, 0x61, 0x6c, 0x6c, 0x2f, 0x00, 0x00, 0x00, 0x00,
>>>   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
>>>   .....etc, then:
>>> const size_t epicsRtemsFSImage_size = sizeof(epicsRtemsFSImage);
>>> The EPICS base libraries contain a weak reference to this same symbol (from libcom/RTEMS/init.c) , and I expected this definition to overwrite the weak one, but inspection of the executable only shows the weak one, and the size variable is not referenced at all. What am I missing? It seems that the tarball file is compiled, but not linked.
>>> Pete.
>> Complexity comes for free, simplicity you have to work for.
Re: linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Re: linking in IOC makefile for RTEMS Johnson, Andrew N. via Tech-talk
Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
Prev: Re: Block CAPUT to not be able to modify PV value Adrian Martinez via Tech-talk
Next: Re: linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
