1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Arbitrary rotation angle with areaDetector Plugin
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, Michael Davidsaver <[email protected]>, "Smith, William" <[email protected]>
Cc: "Kazarski, Sebastian" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 29 Jul 2021 19:55:40 +0000
Hi Will,
There are a few references to external plugins in the areaDetector configuration, such as ADPluginEdge for example - you could take a look at those. I think these files:
would be good as a start.
Hope that helps!
Jakub
From: Tech-talk <[email protected]> on behalf of Smith, William via Tech-talk <[email protected]>
Sent: Thursday, July 29, 2021 3:47 PM
To: Mark Rivers <[email protected]>; Michael Davidsaver <[email protected]>
Cc: [email protected] <[email protected]>; Kazarski, Sebastian <[email protected]>
Subject: RE: Arbitrary rotation angle with areaDetector Plugin
Hi Mark,
I am not sure I understand exactly. I know what you mean generally, I understand how to include support modules in other applications or support modules, but I don't know how to do it with areaDetector. Where are the other NDPlugins defined? Can I just copy the source code and database from Michael's NDWarp into some location in areaDetector core and rebuild?
Thanks
Will
-----Original Message-----
Sent: Thursday, July 29, 2021 8:56 PM
To: Smith, William <[email protected]>; Michael Davidsaver <[email protected]>
Cc: Kazarski, Sebastian <[email protected]>; [email protected]
> This looks perfect. How do I include a new ND plugin in an existing area Detector installation?
You need to recompile your areaDetector application to include this new plugin.  You need to add it to the application dbd file and include the library in your application Makefile.
From: Tech-talk <[email protected]> On Behalf Of Smith, William via Tech-talk
Sent: Thursday, July 29, 2021 11:01 AM
To: Michael Davidsaver <[email protected]>
Cc: [email protected]; Kazarski, Sebastian <[email protected]>
Hi Michael,
Will
Sent: Thursday, July 29, 2021 5:10 PM
On 7/29/21 7:22 AM, Smith, William via Tech-talk wrote:
> Hi,
> We would like to rotate an image using area detector by an arbitrary angle, much like the python function imutils.rotate_bound which rotates an image and doesn’t cut off the corners. Ultimately we are trying to get statistics of an ellipse which is not aligned on x and y.
> Has anybody extended the AreaDetector NDTransform plugin, or written another one to do anything like this? What are other people’s approaches?
It may well be stale at this point, but my NDWarp plugin can do this.
https://github.com/mdavidsaver/ndwarp/blob/2eb73105dd886c9dc89e96b3d77661b9bf770a02/warpApp/Db/NDWarp.template#L40
Rotation being one case of the possible coordinate transformations.
The name "warp" coming from skimage, which I used for prototyping.
https://urldefense.com/v3/__https://scikit-image.org/docs/dev/api/skimage.transform.html*skimage.transform.warp__;Iw!!P4SdNyxKAPE!UoZAMhhQoDunUcHRH1cYxMCLAKIZmIQ9IE3YwpKJGpDISyTmXFgGbtr8odiDEe7x$
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Postadresse:
14109 Berlin
Deutschland
Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
Re: Arbitrary rotation angle with areaDetector Plugin Michael Davidsaver via Tech-talk
RE: Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
RE: Arbitrary rotation angle with areaDetector Plugin Mark Rivers via Tech-talk
Prev: RE: Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
Next: RE: Arbitrary rotation angle with areaDetector Plugin Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
