1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Calc Module of SynApps: Issue with long string CALC$
From: Kuldeep Joshi via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 6 Aug 2021 07:02:53 +0000
Hello,
When I use the bob file with the PV name in the calc record
as IOC.userCalc1.CALC$. I am unable to enter more than one character in the calc field.
On changing it to IOC:userCalc1.CALC (in the bob file) I am able to enter the formula in the CALC field. I understand that $ symbol is used for long strings in the CALC field. In my case it is not  working. however I am unable to have the calc field more than 36 characters.
This is true for all the CALC$ fields in the calc module. The moment I change the PV to .CALC, it is able to take more than 1 character.
It is not having any issues in storing and restoring the values using autosavebuild.
But when i include the userCalcs10_settings.req files in the scan1Menu.req, I am getting a following error when I load the the configuration
PVname saved_value live_value
*** IOC:userCalc1.CALC$    'a/b'                     'a'
This error vanishes if I replace the CALC$ with CALC in the req and bob files. The character count is reduced to 36. I see that the latest calcout record supports 80 characters of the CALC field?
I am using the latest version of SynApps and EPICS on Ubuntu OS. Please advise.
Thank you in advance.
Kuldeep
Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kasemir, Kay via Tech-talk
Prev: Re: cbLow consumption randomly stopping Michael Davidsaver via Tech-talk
Next: Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Epics archiver lost events due to type change Shankar, Murali via Tech-talk
