1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Kuldeep Joshi <[email protected]>
Date: Fri, 6 Aug 2021 12:35:28 +0000
>When I use the bob file with the PV name in the calc record
as IOC.userCalc1.CALC$. I am unable to enter more than one character in the calc field.
On changing it to IOC:userCalc1.CALC (in the bob file) I am able to enter the formula in the CALC field. I understand that $ symbol is used for long strings in the CALC field. In my case it is not  working. however I am unable to have the calc field more than 36 characters.
The ...$ postfix causes the IOC to serve the PV as a byte array instead of a string.
A Channel Access client just sees a byte array and cannot guess if the data is an array of values -128..+127, or if the byte array is really meant to circumvent the old EPICS string length limit and should be converted to a string.
With the command-line caget you need to add or remove the "-S" option to select the desired behavior.
The display builder text entry widget similarly assumes by default that the array is just that, but you can change the "Format" to "String", and then the byte array is treated as text.
-Kay
Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Prev: Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Next: Re: [EXTERNAL] Calc Module of SynApps: Issue with long string CALC$ Kuldeep Joshi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
