1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Getting started talking to a device
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
Date: Mon, 9 Aug 2021 21:25:07 +0000
Marcio,
Thanks, that’s gotten me a lot further than I was last week!
I’ve gotten far enough to try to build my application.  When I run make, I get the output at:
https://pastebin.com/esyPHRC4
Based on that, I added “$(COMMON_DIR)/CsHeater.dbd: $(COMMON_DIR)/asyn” to my Makefile under the line that says “#  ADD RULES AFTER THIS LINE” which changes the make output to this:
https://pastebin.com/ZaftdjaN
This feels like I have some path incorrect or incomplete, but I haven’t stumbled across it yet.
As a summary, I have:
epics_base installed to /home/pi/EPICS/epics-base
asyn installed to /home/pi/EPICS/support/asyn
StreamDevice installed to /home/pi/EPICS/support/StreamDevice
And I am working to create CsHeater in /home/pi/EPICS/CsHeater
     Greg
From: Tech-talk <[email protected]> On Behalf Of Paduan Donadio, Marcio via Tech-talk
Sent: Friday, August 6, 2021 11:16 PM
To: [email protected]
Subject: Re: Getting started talking to a device
Hello, Greg.
All you have is the git repo that you've mentioned?
To build an IOC you will need a configure directory, with configure/RELEASE (or configure/RELEASE.local) pointing to the needed modules, like Asyn. You will also need a Makefile on your IOC application root directory. The st.cmd file usually goes inside an iocBoot/<ioc_name> directory.
My recommendation: assuming that you have EPICS base installed, create a new directory where you want to place your IOC application and, inside it, start a new IOC application directory structure using
makeBaseApp.pl -t ioc <name_of_your_ioc_application>
Then copy the contents of the Watlow-PM/Watlow_PM862FJ-3LEJAA_Module/watlowApp/Db/ directory to <name_of_your_ioc_application>App/Db.
Next, change your configure/RELEASE file, by adding the path to where you've installed Asyn. You must add to the <name_of_your_ioc_application>App/src/Makefile, the Asyn library and dbds:
<your_application>_DBD += asyn.dbd
<your_application>_DBD += drvAsynIPPort.dbd
<your_application>_LIBS += asyn
The DBDs provides you with the functions used in the IOC shell, like drvAsynIPPortConfigure.
See if issuing make brings a successful build.
Still inside the IOC application top directory use
makeBaseApp.pl -i -t ioc <name_of_your_ioc>
This will create an iocBoot/<name_of_your_ioc> directory. Overwrite the st.cmd file with "st.cmd.ModbusAddresses Only" and rename it back to st.cmd.
This st.cmd from the repo only initializes the driver but doesn't load the databases. Without loading the databases, you will have no PV to read/write in the network.
I hope that the IOC application maintainer can contact you to describe which databases to load for your case. I know nothing about the Watlow controller and couldn't help with this.
HTH.
Márcio Paduan Donadio | Control Systems Engineer
Advanced Control Systems Department
SLAC National Accelerator Laboratory | Menlo Park, CA
p: 650.926.5007 | w: slac.stanford.edu
From: Tech-talk <[email protected]> on behalf of Leblanc, Gregory via Tech-talk <[email protected]>
Sent: Friday, August 6, 2021 1:27 PM
To: [email protected] <[email protected]>
Subject: Getting started talking to a device
Hi folks,
I’m still poking around at this whole EPICS thing, attempting to get my feet wet.  I thought that I might try to talk to a temp controller I have on our Cs Sputter source here.  Currently we only adjust the setpoint by walking into the vault and using Bluetooth on our phones.  The controller is an EZ-ZONE model number PM6C1CA-GAAAAAA.  We have an ethernet module for it, and it’s picked up an address from DHCP, which I can ping from the Raspberry Pi where I’ve installed EPICS Base.
I found the pieces that Gary published at https://github.com/tauferg/Watlow-PM though I can’t find the controller mentioned on the Watlow website.  I cloned via git and determined that the second parameter to drvAsynIPPortConfigure should be the ip address.  From Watlow_PM862FJ-3LEJAA_IOC/st.cmd.ModbusAddresses\ Only I have:
drvAsynIPPortConfigure("watlow1", "10.0.0.196", 0, 0, 0)
The next step, per README.md is to “Rename the files and place in the appropriate directories.”  Which files need to be renamed, and where do they need to be placed?  What is the next step here, or do I need to back up and continue working on the st.cmd file?  Any pointers appreciated.
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
RE: Getting started talking to a device Mark Rivers via Tech-talk
Getting started talking to a device Leblanc, Gregory via Tech-talk
Re: Getting started talking to a device Paduan Donadio, Marcio via Tech-talk
Prev: Archiver getDataAtTime and getData endpoints have a timestamp discrepancy De La Paz, Elena via Tech-talk
Next: RE: Getting started talking to a device Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Getting started talking to a device Paduan Donadio, Marcio via Tech-talk
