1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Archiver getDataAtTime and getData endpoints have a timestamp discrepancy
From: "De La Paz, Elena via Tech-talk" <[email protected]>
Date: Mon, 9 Aug 2021 21:11:40 +0000
Hi all,
I have a question about using the different endpoints and the timestamp resolution of the archiver. Here is the situation that is confusing me:
  1. I make a request to the getData endpoint for some <PV> that returns multiple values, each accompanied by a secs and nanos field indicating when the value was updated
Example response for pv ID:  [{ val: “2”, secs: “1627576833”, nanos: “342322864”}, {val: “3”, secs: “1627576922”, nanos: “563728637”} ]
  1. When I make a request to getDataAtTime where the at parameter contains the full returned timestamp, down to the nanoseconds, I get the record value before:
Example request: <ARCHIVER DATA ENDPOINT>/getDataAtTime?at=<UNIXSECONDS FOR SECS OF VAL 3>.563728637 -d [“ID”]
Example response: { “ID”: “2”}
This occurs over shot intervals, so time zone issues are not the underlying cause. Is there some difference in the time resolution of the different endpoints? Is this a quirk of the archiver? We are doing a work around by rounding up to milliseconds, but it is confusing that the timestamp returned in nanoseconds can’t be used precisely in getdataattime
Thank you,
Elena De La Paz
Prev: Re: db/streamdevice/proto Agilent 34970A Dunning, Michael via Tech-talk
Next: RE: Getting started talking to a device Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Phoebus image widget info Siddons, David via Tech-talk
Next: Great Career Opportunity for Particle Accelerator Instrumentation Physicist/Engineer Nicholas James Meyler via Tech-talk
