1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: MCA module's Amptek USB driver fails to connect
From: Ru Igarashi via Tech-talk <[email protected]>
Date: Wed, 11 Aug 2021 20:45:33 +0000
Hello,
This is mostly directed at Mark Rivers but might be of some use
to someone in the same situation as me.
I tried to use the synApps mca module R7-9 to control some Amptek
PX5 SDD readout electronics over USB (Amptek docs say the ethernet
is 10-baseT... haven't had time to test transfer rates to see if this is
still true).  I couldn't get the driver to connect, then traced the
problem to the function "drvAmptek::connectDevice()" failing on
a "hostToIPAddr()" call that fails because a valid IP address was not
given (actually is left blank for USB devices).  I got around it by
checking if "addressInfo_" is empty, and that got the app working
so that I could to some test data acquisition.  But it now occurs to
me that the entire chunk of code prior to checking "directMode_"
should be in the "if( interfaceType == DppInterfaceEthernet)" block.
I haven't tested this yet, but it seems more appropriate.
ru
Ru Igarashi
e-mail: [email protected]
phone: 1 306 657 3751
address:
Canadian Light Source
44 Innovation Boulevard
S7N 2V3   Canada
RE: MCA module's Amptek USB driver fails to connect Mark Rivers via Tech-talk
Prev: Re: Simple binary input question about RVAL? Rolf Keitel via Tech-talk
Next: RE: MCA module's Amptek USB driver fails to connect Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
